Hario Skerton
  • ark
    Re: Hario Skerton
    anyone compare hario and kyocera, please
  • Identity
    Re: Hario Skerton
    thanks TG, would love to take you up on that
    luca - have you seen all 3 hario grinders? theres a box grinder too which looks like it may be japan-only.
  • luca
    Re: Hario Skerton
    Hi John,
    I found the kyocera quite dissappointing for brewed coffee; there seemed to be a lot of fines and the cup struck me as quite bitter. I had a very quick look at the hario and it looked like it might be a little better, but still definitely looked to have a bit of a problem to me at coarse grind settings.
    Using the Kyocera put me on to a trick that is fairly good, though; I have been sieving my grinds through a fairly fine tamis to get rid of the particles that are too fine. This results in a grind that probably doesnt allow as much extraction and, hence, suffers a bit from lack of complexity in brewing. However, the sieved grind is very resistant to overextraction, so you can remedy this somewhat by extracting for a longer time.
    Like people have said, Mecca will have them in Sydney, St Ali has them in Melbourne. The Kyocera grinder had a nicer profile and was a bit easier to use, so Id be quite interested in trying out the mini hario grinder as opposed to the skerton.
    Luca
    Re: Hario Skerton
    Have you tried the Kyocera yet John?
    I will lend you mine if you want.
  • hazchem
    Guest replied
    Re: Hario Skerton
    Originally posted by 1E333239233E232E570 link=1257087945/0#0 date=1257087945
    Does anyone know where to get a Hario Skerton? Im not convinced yet by the Kyocera option and am set on a Hario for siphon/pourover now Ive sold my M4.
    cheers,
    John
    John, I saw a huge pile of them in Mecca when I was there 2 weeks ago. Around $70 IIRC
  • blanyon
    Re: Hario Skerton
    Not sure of anywhere in Aus that sells them, whats your hangup about the kyocera?
  • Identity
    started a topic Hario Skerton
    Hario Skerton
    cheers,
    John
