Hario Skerton
  • Hario Skerton
    Does anyone know where to get a Hario Skerton? Im not convinced yet by the Kyocera option and am set on a Hario for siphon/pourover now Ive sold my M4.
    cheers,
    John
    Re: Hario Skerton
    Not sure of anywhere in Aus that sells them, whats your hangup about the kyocera?
      Re: Hario Skerton
      cheers,
      John
      John, I saw a huge pile of them in Mecca when I was there 2 weeks ago. Around $70 IIRC
        Re: Hario Skerton
        Have you tried the Kyocera yet John?
        I will lend you mine if you want.
          Re: Hario Skerton
          Hi John,
          I found the kyocera quite dissappointing for brewed coffee; there seemed to be a lot of fines and the cup struck me as quite bitter. I had a very quick look at the hario and it looked like it might be a little better, but still definitely looked to have a bit of a problem to me at coarse grind settings.
          Using the Kyocera put me on to a trick that is fairly good, though; I have been sieving my grinds through a fairly fine tamis to get rid of the particles that are too fine. This results in a grind that probably doesnt allow as much extraction and, hence, suffers a bit from lack of complexity in brewing. However, the sieved grind is very resistant to overextraction, so you can remedy this somewhat by extracting for a longer time.
          Like people have said, Mecca will have them in Sydney, St Ali has them in Melbourne. The Kyocera grinder had a nicer profile and was a bit easier to use, so Id be quite interested in trying out the mini hario grinder as opposed to the skerton.
          Luca
            Re: Hario Skerton
            thanks TG, would love to take you up on that
            luca - have you seen all 3 hario grinders? theres a box grinder too which looks like it may be japan-only.
              Re: Hario Skerton
              anyone compare hario and kyocera, please
