Adjusting the length of grinding time on the cunhill
  • BobT
    Re: Adjusting the length of grinding time on the cunhill
    Originally posted by 293D2A212A364F0 link=1259809648/1#1 date=1259991644
    What model is it?
    I assume you mean Cunill? Ive got a Tranquilo, and Ive removed the timing board as it didnt do the job properly. From memory the timer setting went up to a bit over half a double basket worth of grounds. Thats not a fault as such, its what its designed to do.
    As I said, I removed mine cause it was a pain. I now just have the on-off switch, which is much nicer.
    The Cunill timer is the pits. The slightest adjustment to grind changes the dose requiring the fiddly timer to be adjusted. I tried to disable the timer but there were too many wires and I feared Id disable the motor. What did you do?
  • hotshod
    2 hits on the button is the way to go ......
    BUT .... I did see somewhere a person had installed a foot switch to replace the timer .... seemed like a great idea to me
  • garbage
    I have a Tranquilo and have it timed to do half shots and press it twice to fill up the basket.
  • adrianboard
    Thanks Freney. I like the timing aspect of it as so much gets caught in the top half so this way I dont have to measure or weigh or anything. Ill adjust it so I have to press the button twice. Cheers for the input.
  • freney
    What model is it?
  • adrianboard
    started a topic Adjusting the length of grinding time on the cunhill
    when the timing is set to maximum, its pulling up a bit short. do i need to send it in for service? i would rather not as the service agent that sold it to me, a mere 2 years ago, takes around 2 weeks to do anything.
    any suggestions/ piccies greatly appreciated.
