I recently bought a new 09 Mazzer Mini and have been trying to get everything all tuned. The problem I am finding is that the doses coming out seem to be only about 2/3 of a full dose. I have adjusted the dosage bolt in the doser, but it doesnt seem to make a huge difference.
Following the instructions in the manual, it says to determine the grind level, grind small amounts of coffee to test etc. etc. which is what I have also been doing. So I grind about enough to overfill the first chamber (under the shute). Is it possible that I am not grinding enough coffee at the moment to place enough pressure into the chamber to fill enough coffee?
Any help please?
Thanks.
Any help please?
Thanks.
), you will need the entire dosing chamber to be at least 1/2 full.
, so are you saying we are better off loading up with say 200g in the hopper, grinding for a double, then remove the hopper and pour beans back in to the one-way valve bag for use later? then vacuuming out the half ground beans out of the top of the grinder after the hopper is removed? in a domestic situation?? too much for me....... :P
