Mazzer Lux
  • Mazzer Lux
    Gday all..
    I was at my Mazzer bloke today and spied this one- just arrived...
    Mazzer Lux...
    Its close to a mini-manual in body size but with 64mm SJ burrs. It ships with a SJ hopper but all mini hoppers wil fit.
    Current stocks are auto cutout, but there will be manuals as well.
    So if you wanted a SJ but with a smaller footprint, this may be for you...
    Ill see if I can do a deal for a CS bulk buy at some stage  8-)
    Re: Mazzer Lux
    how does it stack up against the super Jolly?
    In our current kitchen the SJ would "just" fit under the cupbords above, and when i say just i mean may not.
    It will need to cope with up to 2kg per day.
    thanks
      Re: Mazzer Lux
      thanks
      The Lux is effectively a mini with SJ burrs- and therefore a smaller donk as well. Like the mini-e which also has 64mm burrs, which are not identical to the SJ, its not designed for continuous operation.
      If you want a faster mini for home, it will be good- as you cant drive a SJ that hard in a domestic envroinment. You can add a mini hopper or short hopper if you wish to cut the height. Pricing is naturally between mini and SJ pricing....
        Re: Mazzer Lux
        I thought the new Mazzer Lux had 61mm blades?
          Re: Mazzer Lux
          Whoops, my bad :-[
          #1. Dont take what the importer says as gospel
            Re: Mazzer Lux
            Looks like it will be a very popular home grinder - faster than the Mini Manual and smaller than the Jolly!
              Re: Mazzer Lux
              Whats the main difference in usability? Duty cycle?
                Re: Mazzer Lux
                Originally posted by 647C79796C7D566468673F3E090 link=1264153532/6#6 date=1268536400
                Its a mini with slightly bigger burrs and a different housing. Id put it at mini duty cycle....max
                  Re: Mazzer Lux
                  Chris [/QUOTE]
                  Originally posted by 55606D6A5E426E67676464010 link=1264153532/2#2 date=1268531436
                  its for an office environment. so when you say th SJ is not designed for continuous operation is this scenario bad then? would that be the same for the LUX? its all about 2kg a day
                    Re: Mazzer Lux
                    Originally posted by 63736D787A6779706C150 link=1264153532/8#8 date=1268543080
                    I think your getting mixed up. I cant quote the mini duty cycle specs, but Super Jollys is 40sec on 40 sec off. Which is adequate for most cafes, ie 2groups flat out. It 10-15 sec to grind for a double, so both groups going = 30 seconds grinding then 30 seconds brewing + cleaning your not going to outpace it.
                    The reason many people use bigger then this is due to speed and grind quality rather the duty cycle. Or your in an extremely busy cafe running 3 or 4 groups flat out.
                    Im not sure on what the mini duty cycle is, the best information I could find was some people saying its 30% on. which could mean anything. 20 sec on 40 sec off maybe. Adequate for any single group machine if you dont mind waiting for it to grind.
