A Week with Mazzer Kony -e
  • #46
    Thanks BLrdFX,
    I'll look into that, did you get them from the States?
    Matt: can I ask you where you go to get the aluminium hopper?
    that's looks pretty cool too.
    • #47
      Hi Joyo
      I was fortunate enough get an offcut from a very generous snubber who had some laying around
      But you'll need to do some measuring - the robur throat is 60.5mm, and 60mm with 3mm wall is a standard aluminium size. Is that the same as the Kony?
      Here is where I worked out what I could get… where are you based? This mob is in sydney. Or Scaffolding guys? We were a bit limited in options out here in the country
      Aluminium Warehouse » Tube Round
      Matt
      • #48
        Thanks Matt
        very generous snobber indeed.
        I'm in Melbourne
        The inside diameter of the Kony collar is just on 60mm, so I say pretty similar to the robur, or perhaps just slightly smaller
        I managed to remove the hopper without breaking the tabs,
        so looking to do something similar to you
        Thanks for that tip
        • #49
          Hi joyo keep us posted if you find anything available in Melbourne. I have a mini but I think the ID may be the same.
          • #50
            Still trying to find anything that works well.
            I've just been using it with the collar and a tamper on top to stop beans bouncing out. Not the prettiest.
            • #51
              Where are you looking, Joyo?
              Get yourself to a sheet metal fabricator and ask for an off cut.
              D.M.G. All Metal Fabrication & Welding - Sheet Metal Workers - Burwood, VIC - Yellow Pages®
              or an acrylic plastic supplier: if they say they don't cut ...... just ask. You only need 150mm.
              Plastics For Industry
              Acrylic Clear Tube Dia.60mm x 2mm x 1M long
              Engineering Plastics | Industrial Plastics | Plastic Fabrication
              ACRYLIC ROD AND TUBE, Holland Plastics, plastic fabrication
              • #52
                Thanks chokkidog for those links,
                I'm in Burwood, will check them out, thanks again
