Minimalism in coffee grinding
  • Minimalism in coffee grinding
    Looked about, but my good buddy Google wasnt talkative.
    I really love variety in coffee, I usually roast 3~4 types of beans every few weeks, then drink them mostly as single origins, swapping from one to the other.
    That means each grind has just a double shot worth of beans in the hopper. Now in my reading, it seems that most machines like a fair wad of beans in the hopper to ensure consistent performance. Well, MY conditions are consistent, just 14~16g in the hopper, all ground in one go.
    My 3 year old Sunbeam EM0480 is starting to die, becoming somewhat inconsistent from grind to grind. What Im after a new grinder that works well with a small volume in the hopper.
    Does anyone have experience with the minimal hopper filling approach? What grinders do a good job under these conditions? Ill pay ~$0.5K dollars or so for anything that will work superbly in this fashion (Im allowed to hope for bargains...).
    Arthur, who cant focus enough to drink the same bean twice in a row
    Re: Minimalism in coffee grinding
    K3T works well for me and with my super small hopper. I only ever load it with enough for a double shot.
    Works well.
    As to ya EM0480..
    1: Strip and clean
    2: Could be bearings / bushes starting to get some slop
    After that drop me a PM...
      Unless I am doing a few at a time I normally just use the Kyocera hand grinder virtually no waste so no need to purge different beans etc. Even with my DRM running really clean at 2-2.3g of waste grinds left behind I still prefer the silence
      Unless you can find one that sweeps really clean in that price range too then doserless makes sense for knocking or sweeping the grinds left behind out to change beans.
        I can also recommend the Hario hand grinder from thingscoffee.
        No wastage, everything gets used.
        Plus two minutes of winding the crank makes you feel youre doing your bit to save the world, and you can call yourself and EcoCoffeeSnob ;D
          @AngerManagement:  I had troubles, so I did the strip & clean, no change. I havent the foggiest notion on how to look at bearings.
          In actual fact, I want to get a better grinder, there was always some consistency of grind issue, how much of it is the grinder, how much the small amount of beans in the hopper, I dont know. It just got worse recently, and is my excuse to upgrade. Dont tell my wife!
          The review of the K3T at http://coffeesnobs.com.au/YaBB.pl?num=1163235531 is quite favourable, your info about it being consistent with small doses is exactly what Im after. Thanks, its now on my potential list.
          @beanflying and @SniffCoffee: The minimalism in the title refers to the amount of beans tossed in the hopper, not the grinder style. I like your suggestions though, I had never thought of a hand grinder being accurate, but unfortunately in the morning I am a spastic, and find it hard to put all the beans in the hopper, let alone doing something coordinated, like hand grinding. For larger coffee making sessions (later in the day)  would be it be *ahem* a real grind?
          Arthur, whose wife does actually want more consistent coffees on Sat & Sun morns, and doesnt care what I do to get them
            Man oh man...  Way back, way back in time..  err is that not an old song  ;D
            There were lots of posts as to issues with the first of the EM0480 grinders..
            Fix those dreaded  (Key words I think)
            Some used plastics and some even turned up wooden sleeves as well as sticky tape; to fix the problem/s.
            Desperation act only... Now get ya self a K3T on order and then pull the EM0480 down and with bits all over the table... Look at ya wife with those doe like eyes... A few butterfly kisses and say..
            Sorry darling... Looks like it has to go and do a detox with Anger up in QLD  :  If it is that bad, we may never see 0480 again
            Then smile the next afternoon when the K3 T arrives...
              @AngerManagement: Just checking, by K3T, do you mean a Compak K3 Touch?
              The Wife is a smart woman, if I try to bamboozle her, she will see through my ruse in a flash. However, if the coffee quality then goes up, she will promptly tut tut in sympathy over my distraught expression at having to replace a dismembered, "this grinder is kaput", machine...
              Sometimes, there are win win situations.
                YES...
                I use a  cut down plastic bottle as my hopper...  I did post in the grinder section some time ago and it may also have been along side my MISS BFC pics...
                I load up for a double at most, but the bottle will also allow for up to say 5 or 6 doubles at MAX.
                If ya get one of the newer ones... Talk Coffee posted some where...  I understand they have changed the grind on demand  switch and of course the mini hopper by default.. Both PLUS moves in my opinion (for what its worth).
                Got to see if I can quickly re wire my K3 T unit...  Grind on demand Vs timed = Only ever use Grind on demand.
                Ya sure she is just not smarter and playing you; such that you feel you have had a win
                A caring and considerate wife/partner :-*
                  Thanks AM for your help, I did finally buy the Compak K3 Touch (= K3T) grinder.
                  The main hassle was the grinder settings are almost impossible to see. That was simply fixed with a small application of whiteout to highlight the markings.
                  I find it very consistent grind to grind. Between 1 mark and the next, I get a ~10 sec change in extraction time. After one go at grinding a new bean, I find it very easy to get a nice ~25 sec pour on the second (or at most) the third grind.
                  Ive had this grinder for about three months, and I have no regrets, and have no urges to upgrade. An excellent grinder!
