Hand grinder for espresso?
  • Hand grinder for espresso?
    So both Tobys Estate and Campos told me you cant use a hand grinder to get a grind fine enough for espresso. I was about to buy the cheaper of the two Harios.
    Im not looking for a perfect coffee, just fresh ground beans for a stove top moka pot or maybe one of those mypressi twist things. Would the Hario grinder do okay for those machines?
    Re: Hand grinder for espresso?
    Originally posted by 5E49485E454F441E1C1C1C2C0 link=1282887412/0#0 date=1282887412
    If you had the choice Get a ceramic burr Hario
    Or a PE De Dienes or Zassenhaus box grinder
    My feeling is
    Yes in most cases it should be fine
      Its not that you cant (after all, theyve been used an awefully long time for turkish coffee), but it may take an awfully long time.
        Not all hand grinders are suitable for Turkish
        However it will take approx 80 turns of the handle for a double shot
        Now you can cancel that gym membership ;D
          Im after a cheapish hand-grinder too. Mind sharing where abouts you are buying one from?
          I had a look at Amazon but a lot of them wont ship to Aus?
          Cheers.
            Originally posted by 3225243229232872707070400 link=1282887412/0#0 date=1282887412
            And the staff you talked to are wrong!
            Consistancy of grind is the key not the ability to produce dust and rocks at the same time. My Zassenhaus is not as good as the Kyocera (similar to the Hario) I own for Espresso but it does a better job on Courser grind settings than the Kyocera.
            Hario is available from Pullman and the Kyocera is available from Supreme Roasters I think to start with but check out the sponsors list on the left Just checked Di Bartoli have both.
            Welcome too
              Consistancy of grind is the key not the ability to produce dust and rocks at the same time. My Zassenhaus is not as good as the Kyocera (similar to the Hario) I own for Espresso. Hario is available from Pullman and the Kyocera is available from Supreme Roasters I think to start with but check out the sponsors list on the left
              Welcome too
              I heard it from a Coffee Gruru
              Tell all of us here and include A2_U2 or is it AU_D2    that a hand grinder can not do espresso  : : : Supreme Roasters
              I even use a cheep wooden one set to fine and it does espresso when camping..  Hard work but not imposable..
              Now a good Turkish grind is another matter and Hand or Machine... They have to be bloody good to give a good Turkish grind on demand and all the time..
                Cheers.
                Im not sure what the policy on posting retailers is here. But if you look back to my original post you should be able to work out where I was looking at the grinder
                  I had nothing but a Kyocera hand grinder for the first 6 months of having my espresso machine and it did a great job, and for a few reasons.
                  Firstly, it can grind finely enough, no doubt, the Kyocera grinds to powder if you tighten it enough. The downside to this is you dull the burrs quite quickly if you get into Turkish coffee with it, which then gives you lots of fines in courser grinds when you dont want them.
                  Secondly, having the hand grinder only and having a few different beans going through the grinder at anytime meant I had to learn the ins and outs of grinding pretty quickly. Youll quickly get to know your grinding, not buy numbers on a collar but with your fingers.
                  Theyre the upsides, but the downside of time involved is quite a major issues. You grind, pull a shot, need to make an adjustment then three mins later youre ready for another shot. That might not sound to bad, and its not life or death, but it is frustrating. If youre like me and have a La Pav, needing to regrind means youve lost your window for that hour due to the bloody thing overheating. Just before I bit the bullet and got a Mazzer I kept a drill in the kitchen, on a slow speed its a rough n ready arm reliever!
                  To answer your question, I guess in a long winded way I just said yes.
