Mazzer mini issue?
  • Mazzer mini issue?
    I got a Silvia for christmas which I tried to use (and failed) with my sunbeam em430 grinder. After mucking around for a few days I knew I had to get a better grinder to get the most out of the Silvia, so I went ahead and purchased a Mazzer Mini.
    When I first set it up, i found the zero point by running the grinder and moving the dial towards the finest setting. As soon as I heard the chirp I backed off a little.
    Over the last week I have been playing with the grind settings, going up and down to see what affect it has on the pour. Ive been putting 2-3 doubles worth of bean in the hopper at a time.
    This morning I decided I would just run it without the hopper. As I was now using a new batch of beans, I re-found the zero point and backed off so I couldnt hear the burrs touching. Put in enough beans for a double, and ground them. As the grind came to an end, the machine started making that "burr touching" sound again???
    Has anyone experience this problem before? I havnt taken off the top burr carrier to investigate. Is it possible that the nut on the lower carrier has come loose and the lower burr is moving? As this unit is less than a week old im a bit apprehensive doing too much with it if it has a problem that is covered under warranty.
    Thanks for reading my loooong post
    Darren
    Re: Mazzer mini issue?
    Originally posted by 183F3D351431272737500 link=1294276334/0#0 date=1294276334
    This morning I decided I would just run it without the hopper.As I was now using a new batch of beans, I re-found the zero point and backed off so I couldnt hear the burrs touching. Put in enough beans for a double, and ground them. As the grind came to an end, the machine started making that "burr touching" sound again???
    It could be
    1) some loose bean particles
    2) a stone ??
    Unplug the machine first
    Unscrew the top burr and vacuum then inspect
    Its the only way to be sure
      Originally posted by 0B2F262625251F0B2F332D2F400 link=1294276334/1#1 date=1294276594
      It could be
      2) a stone ??
      I would say that KK is on the mark there When I Chang grind to finer with no beans in I some times get that sound its a small amount of grinds on the burrs..
      Cheers Gra..
        Well, last night i pulled the top burr off and cleaned it out. There was a lot of coffee in the burrs and im 99% sure this was causing the noise. After re-assembling the noise was gone.
        Thanks for the pointers
