Hi Guys,
forgive the noob question. Trying to choose among the top three. Ive done some reading and it seems the obvious choice would be to go to the most expensive in the list - but i need some advice...
Is the lelit and the IC essentially the same thing? any real difference? clumping, noise, grind quality? the lelit is $50 cheaper so id opt for that... the overall price isnt too bad either...
Im obviously grinding for espresso, but at work I have an aeropress (which is pretty fine grind too). I think the adjustment of the above two will be annoying. I will grind for the working week then return to espresso at home, so its not frequent changes, but im guessing marking the colar of the K3T is all that is required to relatively easily swap b/w the two grinds....
(or are they similar enuff grinds that the lelit wont be too bad)
finally is the compak really that much superior in terms of noise, mess longevity and not clumping?
(these are all doserless btw)
(for the espresso machine im heavily leaning lelit or silvia, the latter probably being more finicky for grind)
Thanks all, some experiences or even just comments are greatly appreciated!
Joe
Joe
