Oh Help!
  • Oh Help!
    Hi fellow grinders, I am the very proud owner of a compak k3t so excited after using a EM480 which didnt impress me much.
    Anyhow I am still on a steep learning curve with all things coffee so I need to dial in this baby.
    I just want to confirm (the instruction manual is terrible) that you need to unscrew the 3 screws in the adjusting collar and move the collar around to put it to a new setting, then steplessly adjust with the grinder going ? I hope this makes sence and if you have a compak I think it will.
    I did purchase from a sponsor but it was hot and late in the day and I didnt get a very thorough demonstration.
    Re: Oh Help!
    Hello bigdog,
    Just move the entire collar. The collar only needs to be removed to access the burrs for cleaning.
      Re: Oh Help!
      You should only need to adjust the step-less adjuster
      The quickest way is to get the right ballpark  grind is to grind to a consistency of table salt
      To fine tune - adjust to course or fine with a few shots on your machine as required
        Re: Oh Help!
        Yes i hear what your saying just move the collar. But it only moves a short way from the front then about a 1/3 turn to the right (finner) and wont move any further, and the grinds stop comming out. I move it back (left) so the grinds start comming out again but its too corse.
          Re: Oh Help!
          Originally posted by 2338332E2F6F32282C31322E2F410 link=1296965475/3#3 date=1296969401
          Well then you have more adjustment than you require.
          The espresso area will occur across a zone of less than 1cm between these two extremes.
            Re: Oh Help!
            Thanks guys, Im getting there now!
