Hi peeps,
I have the K3Touch/Wega mini instant v1 with the straight chute, as we all know of the build up issue in the chute, i have been scooping out the grinds with a little long handled spoon but the other day a piece of the chute broke off. I thought that this was a perfect opportunity to open up the unit and remove the screwed in chute section and modify the chute to slant downwards to prevent the grind build up.
The problem being is that to get to the screws i need to take of the front panel which means getting access to the bolts inside that are obstructed by the grind motor. Can someone explain how to remove the motor or point me towards a webpage the details how to do this. I have had a search on google but everything tens to discuss removing the burr set.
Hope someone can help out.
rob
rob
