Any thoughts on the Macap M4?
  • Any thoughts on the Macap M4?
    Hi Al
    I think i have settled on upgrading to the macap M4. What is the general consensus on this grinder. I have come to this because i prefer the dosser and the screw adjustment,
    Does anyone have an issues with the M4?
    Re: Any thoughts on the Macap M4?
    I have an M4D. The only problem I have with it is that its not an M7!
      Not sure if I should spend the extra? I need to be convinced its worth it
        Macap are excellent grinders and directly comparable with the likes of Mazzer. If you prefer the aesthetics/ergonomics of the Macap over other grinders, then go for it mate. I owned a Macap M4 and a much larger commercial grinder at the same time. Both grinders had new burr-sets (the Macap was brand new) and there was no way I or anyone else in these parts could pick the difference, in the cup.
        Quality of build is also excellent and will outlast you if a modicum of maintenance is expended regularly. Best thing of course, is to try and visit one of our Site Sponsors to road-test various grinders at this echelon and then make up your mind from there. Youll know exactly what your buying then.... 8-)
        All the best,
          Thanks Mal. The m4 is the way to go for me..
          D or not to d is the question...
          I am worried about clumping in the m4d and if I get the m4 I will wish I got the d version...
            Kanda, I have the "D" and I certainly dont regret it. I have found clumping [when it does occur] is very minor. I grind into a old yogurt container and give it a quick wisk with a piece of thin brass rod and it is fine. I would love the M7D but at this point in time it is not even in consideration. The M4 & M4D are basically the same grinder dosered & not-dosered.
            Steve
              Ive had the M5 (bigger hopper) for a few years now and its been excellent.
                Where are you located Kanda? There may be a sponsor close by where you can play with, and compare the two to see which you prefer.
                Steve.
                  Hi Steve,
                  Yes and no. The M4D runs more aggressive burrs and is much faster. Think 20+ sec. for a double v 10 seconds.
                    I have visited the sponsors and all great help. But trying to justify the m4d if the m4 is all I need! The only reason I would get the m4d is to prevent future upgradeitis..
                      Originally posted by 6B5E5354607C5059595A5A3F0 link=1306493742/8#8 date=1306580284
                      Doh :-[........yes of course.......my bad. My average grind time for 19-20gm is 9sec. I remember now why I seldom try to give advise..........Im not always as accurate as I might be :-[
                      Originally posted by 545E515B5E080E0D3F0
                      link=1306493742/9#9 date=1306581149
                      There is no cure known..........only treatment of symptoms ;D
                        M4 = better value for money.
                        If you want to spend more go up a class!
                          Originally posted by 0304000304000304000F0413610 link=1306493742/11#11 date=1306588311
                          Very good point. I think thats it.. Decision made macap m4 for me!
                          Thanks for all your help
