Hi Guys, which Grinder is better to get flavour from your beans. Assuming barista is skilled at using both.
Major E or Robur Doser
Re: Major E or Robur Doser
Hi Phat,Originally posted by 1E262F3A0C21374E0 link=1308475776/0#0 date=1308475776Hi Guys, which Grinder is better to get flavour from your beans. Assuming barista is skilled at using both.
I really dont think you will taste any difference whatsoever in the hands of a skilled barista who free doses with a Robur.
The Robur-E will be quicker and lead to less wastage.
Hope that helps
Well....
I havent sampled espressos from a Major-E, just a straight Doser version. Compared to my Kony-E, I prefer the slightly brighter and broader flavour spectrum of the Kony.
Probably the only way youre going to be able to determine which is best for you, is to sample brews from both and maybe throw in Macap M7D to the options mix too...
8-)
Hello all.
General rule of thumb for "regular" flat (planar) plates as supplied at original fitment say 400 kilosish give or take, and for conical burrs say double.
Dont expect earth shattering differences, and as stated you must do a side by side, one on one test. Anything else will give silly results. Also, suggest you are not looking for a "blind" test. You are (I think) looking rather, to adjust both grinders down to a point where they are both resulting in best possible brew with same beans, operational technique and machine, and then cup and judge the different nuances (if you find any) between the two.
Dont expect to get one that is "better" than the other, expect rather to get a minds picture of the different nuances (if you find any) between the two and decide which you like better for whatever reason. Everyone is entitled to their own opinion, and remember that your opinion might change when you change the type of coffee beans you put in the hopper!
Rgdz,
Attilio.
Arh yeah just had another thought wrt comparo.
In the interest of obtaining a true result would rather not compare them where one has new burrs and the other hasnt, and would rather not compare a conical to anything unless it has quite a few kg under its belt.
Of course as usual, thats just my opinion...
Cant see a major delivering "slowly" whether the plates are worn or not.
Rgdz,
A.
Hmmm....Originally posted by 7E464F5A6C41572E0 link=1308475776/6#6 date=1308920420major electronic is dosing around 18-20g in about 10 seconds
That seems a little slow. Pretty sure Ive seen demo videos that do this in less than half that time....
P.S.
As per this one for 16g
[media]http://www.youtube.com/watch?v=KQr7qEpEK_o[/media]
@ Mal - the 3 phase 380V Mazzer Major is indeed a lot faster than the 2 phase 220-240V Major. Thats not massively surprising, but its annoying that people dont make it clear which is which when doing demo videos.
I know the new Kony Es (like bjecks) are a lot faster than the old Kony Es - perhaps some of the Majors also have this problem?
Chris, I think you got Major mixed up with Kony for the question.
OP - For my money, Id go conical over flat burr every day.
Erm...I may have done that John ;DOriginally posted by 4A67666D776A777A030 link=1308475776/8#8 date=1310197545Chris, I think you got Major mixed up with Kony for the question.
I am with you on the burr type though. Conical for me too.
P.S. Welcome back! long time.
Looking at the power cord, it doesnt look fat enough to be 3-Phase which operate at higher voltage and require thicker insulated cores (usually).Originally posted by 002D2C273D203D30490 link=1308475776/8#8 date=1310197545@ Mal - the 3 phase 380V Mazzer Major is indeed a lot faster than the 2 phase 220-240V Major. Thats not massively surprising, but its annoying that people dont make it clear which is which when doing demo videos.
I know what you mean though, a little more specific data would be helpful....
Totally agree - I think most people I talk coffee with these days can taste the difference, but sometimes you taste it because you know its there. Blind/blindfolded taste-offs are the best option to work it, with a barista friend!
Remember, your mileage will vary with the bean you use.
Wow - that was pretty quick!
Originally posted by 7F52565A573B0 link=1308475776/7#7 date=1308923860Hmmm....Originally posted by 7E464F5A6C41572E0 link=1308475776/6#6 date=1308920420major electronic is dosing around 18-20g in about 10 seconds
P.S.
Yep, very true...Originally posted by 64484B4E497870270 link=1308475776/13#13 date=1312610489Grind time depends on grinder setting.
Finer grind = slower grind time for same dose.
This was supposed to be an espresso grind though and fairly indicative from my own research....
