Re: Cunill El Cafe Tranquillo
Will do Mal. Thanks for that.
Gday MrK...
Nice work mate... 8-)
I just reduced the size of your image files - If you can try to keep them to around 100KB in size and within a frame of 800x600 Pixels that would be excellent... [smiley=thumbsup.gif]
I dont know, I think you could do this to any doser grinder (lets exclude the mazzer range from this list). Im personally thinking though the next switch mod I do I want to build up a big red button that has "Fire Ze Missiles" printed on top of it under a glass case that requires a key to access it.
It would look great but annoy the c**p out of me after a week or so.
It wourl be a crime against nature on any other grinder, but on the Cunill El Cafe Tranquillo its just perfect, Huston we are go for grind ;D ;D.
So, a word to the wise, never let me loose in JayCar alone again. I need adult supervision. I may have (read definatly have) brought a missile switch, because they look cool.
Photos as follows
No worries Liam...
All the best,
Managed to solve it (yay!). It turns out that the doserless Cunill and the doser use the same starter Cap for the motor and therefore the timing board provides no voltage or current regulation.
Essentially I was ablre to byass the timing circuit board and go from the grinders main Power switch straight to the motor.
The timing board annoyed me anyway and I am loking to put a toggle switch in where the timing board was, it will just make things a little easier with my layout to put a switch on the other side.
On a brighter note I got to clean my grinder out which was well overdue.
I will post photos of what I have done once the toggle switch is instaled (Yay, JayCar trip time(like I need an excuse!)).
Liam
Gday Liam....
No photo to see as yet.... :-?
I have a Cunill El Cafe Tranquillo Doserless grinder and have burnt out a resistor on the timing board.
I was wondering if anyone who has one of these could have a look at the timing board and tell me the resistor value in position R7 (The largest resistor on the board) it would be much appreciated.
Liam.Tags: None
