Dramas with Compak K10 Fresh
  • Dramas with Compak K10 Fresh
    Ive just purchased this from a fellow CSer. When I unpacked it Friday night I had to run the grind out to almost full corse to get a shot to pull. No after some more grinding (as suggested to bed the burrs in) I cant adjust the grind more than a turn (less than 10% of the  range).  Am mildly stressed any assistance greatly appreciated.
    Re: Dramas with Compak K10 Fresh
    Sounds like a warranty call. Mine is perfect, pulls perfect shots around 20 on the grind scale. Funny thing I have noticed is how infrequently I need to adjust the grind and I am chamging beans all the time. Coming from a major its a big difference.
      There is a pin under the collar to limit the range of travel. Also the 0-100 range can be set anywhere you want it to be.
      It should be an easy fix. If youre not sure you have the skills, any techie will be capable of adjusting the grinder correctly.
        Yes, off to a tech yesterday will report back once it comes home again.
