Grindz for Smart Grinder?
  • #16
    Re: Grindz for Smart Grinder?
    Originally posted by 143335323F460 link=1311823010/9#9 date=1311925976
    One word of caution - if you remove the bottom burr just make sure you replace the spring washer when reassembling.  I somehow didnt notice I hadnt even replaced it and the nut worked loose during a grind  :-[
    I know - maybe Im the loose nut  8-)
    Hi, what does this Spring washer look like? I dont recall fitting anything else besides shims when I cleaned mine out.
    • #17
      Looks similar to this:
      It sits between the bottom burr and the nut.
      When I was shimming mine up, sometimes some shims were stuck inside the bottom burr recess, so give it a tap to dislodge any that may be up there when you take off the burr, so they dont fall out without noticing.
      • #18
        Yep, definitely had to put that back in. Silly me thought it was a cracked shim and left it aside.
        Thanks so much artman! /thumbsup
        • #19
          My shimming instructions said to throw the spring washer away. lol. Good thing I put it aside in a safe place.
          Now if only I could remember where the safe place is...
          Oh and I find that the best way to clean old grinds out is with a vacuum cleaner. It seems to get it all and much easier than brushing
          • #20
            I haven’t used any Grindz.
            I added one shim to the 3 originally installed. I didn’t find any washers below the nut. Perhaps they fell on the floor. The machine is working perfectly.
            Barry
