Wega 5.8 Instant - what am I doing wrong?
  • Wega 5.8 Instant - what am I doing wrong?
    I bought a Wega 5.8 Instant (same as a Compak K3 Touch) today from Di Bella but unfortunately they are closed now and cant work out what Im doing wrong.
    Ive put some beans into the hopper, opened the shutter, turned on the machine but nothing is coming out the other side.
    I took the hopper off and scooped out some beans and can see that its grinding. Anyone know what Im missing here?
    Re: Wega 5.8 Instant
    Welcome to CS.
    Most likely set on far too fine a setting. Open it up to a much coarser setting and try again. If that is the case you also might want to stick the vacuum cleaner up the outlet of the grinder and clear out the fines that have got bogged up.
    Once it starts to produce grinds out the spout, if it needs to be fined up only do it with the motor running.
    You will have to take it from there, and I hope that helps.
    Rgdz,
    Attilio
    very first CS site sponsor.
      Re: Wega 5.8 Instant - what am I doing wrong?
      Thanks Attilio! I didnt go the vacuum route as my wife was giving me dirty looks but simply used a chopstick and turned the machine upside down.
      Interesting that the setting from factory is too fine. Had to dial it back quite a bit actually as my poor little Breville felt like it was going to explode.
