which Compak to get
  • which Compak to get
    I would like to upgrage my grinder so should I get the K3 Touch or the K3 Elite to replace my Breville smart grinder. Is the manual doser a good idea or should I just stick with timed dosing directly into the porta filter. Will the K3 have plenty of adjustment left to grind finer after I have it set up for my BDB
    Re: which Compak to get
    Hello Tony, I suggest that you consider the k3 push grinder. Its very similar to the k3t without the timed dose and is much cheaper without compromising on quality. I have never come across the perfect timed dose grinder - some come close. The Compaks are a big step up from your current grinder and will have plenty of room to adjust finer than required for espresso. I dont however recommend any non-purpose built grinders for obtaining a Turkish grind.
    Dennis - cuppacoffee
      I Definitely agree with Dennis here, the K3 Push is brilliant. Get it, you will love it.
        Me 3 on the push.. Great grinder loving my new one
