Here are some more pics of my FJ Grinder. Now to repair the illuminated sign.
Climax Grinder
Tried another espresso this morning. With the grinder adjusted as fine as I could get it without the burrs touching and packing the basket with 2 extra gms it makes a just acceptable espresso. However from what I have read and the uniform grind coming out of it sure it will be good for filter coffee.
Here is a pic with a quick patch up of the sign using a bit of loose perspex I had lying around and a bit of work with the ink jet printer and some supaglue. I glued the sign on the back of the new perspex.
- Likes 2
Not bad with the printer, the whole grinder reminds me of walking through Woolworths as a child. I think your great grand kids will still be able to make filter coffee with that
- Likes 3
338, I remember them too and that is the main reason I bought it. I really did not need another espresso grinder. Sad to see the way it had been knocked about. Bit cheeky though about how they put "espresso" on the dial and almost certainly why they no longer use ghost burrs on their shop grinders. Very similar to units sold in the US under the Bunn or Grindmaster brand in the past.
- Likes 1
- Likes 3
Oops, my turn for a long lag apology 338 - not ignoring you, it just got buried.
Both grinders are from the very early days of CoffeeSnobs and were stolen in The Great Snobbery Robbery of 2007
https://coffeesnobs.com.au/forum/new...nough-to-steal
They were used to grind fresh roasted orders until they went on a walk.
Then about 12 years later Paula spotted them in a local auction listing
https://coffeesnobs.com.au/forum/new...322#post706322
Funny how karma comes around to sorting everything out eventually. Police tell us the original drug stuffed thief died and his step-father found them in the shed and tried to sell them. No charges were laid as dead people don't often turn-up to court. They are now Snobbery history and sit around here getting in the way but I love them just the same
I'm pretty sure Ted2013 that my one on the right would have had a cloth covered power cord originally, the design seems too old for a PVC one.
...and I agree, I think in the timeline, your's would sit in the middle of these two.
What's your serial number, they might all be sequential?
- Likes 3
These can be found at Link removed as per Site Posting Policy Andy's seem to be the second model and the one of the recent models G, H, J, K.
I note that the web page says spares are available for models G to L (L and LS are the current models).
It also says cutter upgrades are available for C, D, F models.
I am not sure but suspect the DF and FJ are the models with the cast ghost burrs (certainly the FJ is) and am not sure cutter upgrades are available. There is no pic of D model and the FJ model is significantly different to the F model.
My Climax C60 turned up this morning, I have completely stripped it and will clean / relubricate everything as it goes back together.
It's an FJ similar to the one above but it has replaceable flat burrs, alas the older model with two fixing screws and they are quite worn. Other than that everything seems to be in good nick.
I have asked Climax whether the new 3 screw "upgrade" burrs are available for this model. The upgrade burrs appear to be aluminium plates with Anfim 75mm flat burrs mounted on them.
One thing I noticed on disassembly is that the fitment between the feed screw and the section of the grind head through which it passes is fairly poor, there were a lot of bean fragments behind the feedscrew. I'm going to see if I can sleeve this with HDPE to alleviate the problem.
Seems to me that with a slower motor and better adjustment this thing could be a half decent grinder.
The thread on the adjuster looks like M10 fine which is a common size on bicycles (rear derailleur mount) so I have the appropriate taps. I might try making a larger adjustment mechanism in brass and see if that allows finer adjustment.
- Likes 1
