Hehehe. Yeah. I want one.
New Release: Mazzer Robur Electronic
Re: New Release: Mazzer Robur Electronic
I dont know if itll be quite $4k, but you can bet that it wont be cheap. But if it does end up being expensive we can always take a regular robur instead ;P Mind you, Chris is on the ball - check it out.Originally posted by Coffee Kid link=1193020344/0#1 date=1193021496Wow!! Looks interesting
Hmm now the price?... Guessing around $4k. Me would like one too.
If they do a three phase version of it, with the computer fan in the back it looks like it might actually allow you to do grind on demand in a busy espresso bar, which would be great. But, as always, I think its a case of waiting and seeing.
I find it strange that they didnt put the pf holder fork on it, like they did on the mini E. OK, its fast, but that pf holder fork is very convenient.
Luca
Yes,
Pretty impressive grinder if the $$$ are there to get one. Its available from ourselves or new CS sponsor Genovese.
Present pricing is just over $3.2k but Id expect that it will follow everything else up in due course....
So... that is the fork, not the holding folk (which allows you take your hands off the pf.)Originally posted by Theodore link=1193020344/0#3 date=1225219189Looking at thhis video, I see, that the fork, is in place.
http://video.aol.com/video-detail/mazzer-robur-electronic/3505363092
So...?
*Note the holding fork on the mini e below
Maybee they think it is so fast that it is not worth taking your hands off the handle to wipe your brow?
If you see this, http://video.aol.com/video-detail/mazzer-robur-electronic/3505363092 ,Originally posted by jimmyb link=1193020344/0#6 date=1225368760looks in place on the pic too
as Luca said, could be good for a cafe that grinds to order.
you realize, that the time to grind, is below 4sec.So, either there is a fork, or not, it is not a problem.
At the risk of sounding like an expert when Im not :
, Id take that review with a bit of a pinch of salt, especially when it comes to an Aussie market. The main reasons that spring to mind are:
1) Home roasted blend of unknown quality, even inter-shot.
2) Unknown quality of supplied power @ a different voltage.
3) In my experience, dosing a gram weight of beans is open to as error as by eye/tool/barista. The simple fact is that beans vary in hardness (thus weight), can popcorn if they dont have beans on top of them etc, and at the level theyre trying to interrogate the grinders at, and with 5 different beans in the roast, weight to surface area may vary a lot per-shot.
4) Some grinder/bean/machine combos work better than others. eg. My Macap M4 is a superior grinder to the [Insert Current Supplier Here] KS, however the burrset of the KS seems to be a good partner to some beans, whichever machine I use, and other beans sparkle through one of the machines in specific. I think this comes down to extraction profile, which is one reason Id love a LM GB5 or similar!
Our Robur-e arrived this morning and all I can say is WOW!
We had the pleasure of visitors: AndyL, Con H of 7 grams (thanks for dialling in Con while I was up to my elbows in a machine [smiley=thumbsup.gif]) and Nathan of Somage...Shots everywhere
The Robur-e is clean, quiet, and quick. I can see what all the hype is about and everything else I have used so far pales in comparison.
Its worth every cent!
Shots are gorgeous...but then they always are on the Faema 8-)
Hi KK,Originally posted by 684C454546467C684C504E4C230 link=1193020344/12#12 date=1246429695May I ask how the Robur compares to a Kony
1) grind (2) size - as in side by side
and does the Kony come in electronic ??
There is a Kony-e. The difference is that with a kony, you put the kettle on, then go for a walk around the block etc...
The kony is more like mazzer mini speed.
Kony-e is 650mm tall:
Power: 350 Watt
Burr diameter: 63 mm
Burr speed: 420 r.p.m. (@50Hz)
Hopper capacity: 1.3 kg
Net weight: 20 kg
RRP: $2530
Robur-e is 720mm tall:
Power: 900 Watt
Burr diameter: 71 mm
Burr speed : 420 r.p.m. (@50Hz)
Coffee-bean container capacity: 1.8 kg
Net weight: 28 kg
RRP: $3605
