Grinders Less then $200
  • Grinders Less then $200
    Anyone can suggest me a good grinder i can get for less then $200? Was thinking to get the Sun Beam 0450 or a De Longhi k100.
    Nick
    Re: Grinders Less then $200
    Dont know anything about the sun-bean, but please dont go with the de-lonnnnnngggggi if you are going to use it with an espresso machine.
    Ive reviewed a few in the very low price brackets and some in slightly higher price brackets and at that price level it is hard to get something that works OK for espresso and that will continue to do so. This is the operative phrase....."continue to do so". They are usually always substandard in the adjustment department.
    Essentially there is nothing "good" down there for esp. however we are currently reviewing one that we think may do the job. For how long I cant say......but it seems to be better designed than all others weve looked at so far in the area of the adjuster mechanism.
    Contact me off list in a couple of days by which time I will have brought a new one up from the workshop (where we are checking build quality) and had it sitting next to our machine in the lunchroom for myself & staff to use and comment.
    If it works out it will probably be somewhere around $135.00 with delivery included as long as you are in NSW/ACT/Vic/QLD and more if elsewhere. Maybe I will let u have the test model for less if it works out ok........it will only have been used by us / me for a short time for assessment.
    Just remember, u gets wot u pay 4!
    Regardz,
    Attilio
    first / original CS site sponsor.
      Thanks for the useful info, i will be using the aeropress to make an expresso, no machine for now as im still new to the whole coffee scene.
      So in the meantime, i just need a good grinder to go with the aeropress and maybe later on i might be able to use it again when i buy a presso.
      Nick
        Manual grinder?
          depends on the cost, any suggestion?
            at $200 you should be able to get a em0480. Especially with the rubber thingy on the spout, a very good grinder for the price.
              My advice FWIW, save your $$ and then buy a grinder you can keep rather than an appliance which will ultimately fail or need to be upgraded.
              Keep your eyes peeled in the hardware for sale thread for a Rocky or something like Myrtles Compak K3E which was an absolute steal.
              Also, sponsors sometimes have demo grinders and/or special offers which will deliver quality at prices which are more than fair.
              Enjoy your journey...
                actually in the for sale section, theres also timos Cunil Space.. If i hadnt just got my compak i wouldve grabbed this. it looks even better up close than it does in the photo and I can certainly vouch for how well Tim looks after his equipment.
                  http://coffeesnobs.com.au/YaBB.pl?num=1220157614
                  At that price, Im very surprised its still there - serious piece of gear. In a decision between that and a Sunbeam - no contest. No need to upgrade in 12-24 months (very big on the bench, though).
                    That looks like an awesome grinder to have and no doubt it will give a nice grind, however, the space in the kitchen is very limited.. hence i have an aeropress.. i need something small enough so that i can put it in storage after i use it.. but thanks for the suggestion!
                    well at the moment im thinking to get a new sunbeam 0480 which i can get for $180, but i guess the question is, what is the best grinder to use with the aeropress or the presso...
                    Nick
                      Nick
                      Hi Nick
                      Had a customer ask me a similar question yesterday, "Will the quality of the grinder make a difference when using an aeropress?" My answer was that the quality of a grinder will make a difference no matter what method used to brew coffee.
                      So, I would suggest to you that the answer to your question is probably, "the best one you can afford".
                        what about the little isomac, its $260 I think. coffeeparts has them
                          Hi Guys, Thanks for your input but i decided to get the sunbeam 0450 instead. No problem so far! except for the static it produced . Setting is on 12 for the aeropress.
                            Get the plastic / Silicon snout from Sunbeam and then grind into a tin or you PF... Static is almost Nil.
