I am using a Mazzer Super Jolly but I presume the correct procedure would be the same/similar for all machines. I am not exactly sure of how Im supposed to properly use the machine (with doser) so could someone correct the following steps if they are incorrect?
1. Ensure that there are no foreign objects in the grinding well (I presume this should be free of grinds/beans from the last use).
2. Turn on the grinder
3. Put in desired quantity of beans (if I want 14g or so for a double basket approx. how many grams of beans should I be putting in bearing in mind I have a doser?)
4. Wait until the grinding well has been swept as clean as it will sweep
5. Turn off machine and cover grinding well (hopperless)
6. Dose
I guess my main questions are whether the steps are correctly ordered (eg. turn on grinder before putting in beans or vice versa), and what quantity of beans results in what quantity of grinds).
Yes I will "trial and error" but beans are expensive and secondly Im bored at work waiting for home time so I can buy some fresh beans and play
6. Dose
