Hi All,
I have recently acquired an Anfim Super Lusso grinder from a well known place
. For £ 30 I thought it was worth investing
The grinder is a beast sporting 0.6 Hp (450 Wats) and 75 mm flat burrs. It is also well known for its good distribution.
Below you wil find several pictures showing the progress of cleaning.
That was before I started although I had already removed tons of giunk before I took the picture.
And this one is after the cleaning:
The burrs looked Ok to me but I have to admit, I do not have any experience with grinders/burrs so it is difficult for me to judge.
Looking at pictures (if that were possble) can you let me know whether the burrs look OK?
Upper one:
Bottom one:
It grinds consistently. I choke the machine at the 5.5 scale. Zero is at 1.5.
Is there any way to determine whether the burrs need replacement? In the long term I have decided to go for it (in six months time may be) but if necessary I might bite the bullet now.
I wish to thank you in advance for your help!
John
PS For higher resolution image, once you open the image in the post click one more timein the Image Shack to get a larger image.
PPS I have opened another thread here:
http://www.toomuchcoffee.com/index.php?name=PNphpBB2&file=viewtopic&t=7667&post days=0&postorder=asc
but as it is members only area some of you might not have access. Another thing is it looks as Anfims grinders are not very popular for home use (too big=ish?)
Upper one:
Bottom one:
John
