Re: simple mods for messy EM0480
the lamination film is a good idea, should be about the right stiffness and should hold the slight creases needed for the back corners; might hold a curve better than mine, too, by rolling over a table edge or something
I mentioned that mine tends to lift a little at the front
this is because the grinder turret tapers upwards ie its slightly conical, not cylindrical
pushing the front of my screen down leads the sides to angle in ever so slightly, which sort of matches the turret
if yours material is stiffer and the front is lifting too much, perhaps re-design the screen template so that the bottom edge is not straight, but the sidewall bases angle down by a few mm as they head towards the front tabs
Michael
Michael
