simple mods for messy EM0480
  • cksyd
    Re: simple mods for messy EM0480
    Originally posted by 6B4643595E4B43581B2A0 link=1240137979/12#12 date=1240315024
    This is a mod that I have found works very well to prevent messy grinds overflowing onto the bench. I started with cutting a Styrofoam cup to fit just on the inside of the PF but then a Humphrey (a fellow CSer) found if you cut a bit further and make it a slightly tight fit it clicks on and doesnt just fall off. I have now adopted this method and it means you can give the PF a bit of a shake to level out the grinds then take off the grind guard and level off and tamp. Works very well!
    Hey Alistair
    Thanks for your post!!
    We tried this today and I have to say this appears to me to be the best work around mod of any that I have seen.
    Hardly any mess on the bench and 25 styrofoam cups for $1.60!!
    Shall be doing this until further notice...
  • willsy01
    Whilst my method is far from pretty, ive just hacked up a 2 litre milk container.
  • Senator
    Did the paper template yesterday, checked the measurements at home last night and have done the laminating sheet this morning. Would definitely recommend the laminate sheet, its 80 microns thick
    Has come out quite well (unfortunately the laminate left some streaks in the sheets, but its ok) and I scored down the lines that sit at the back of the grinder to enable the folds, plus have some quite long tabs for the bottom.
    Not back home till 10:30 tonight so will have until tomorrow to see what impact it has on the mess.
  • mcrice
    the lamination film is a good idea, should be about the right stiffness and should hold the slight creases needed for the back corners; might hold a curve better than mine, too, by rolling over a table edge or something
    I mentioned that mine tends to lift a little at the front
    this is because the grinder turret tapers upwards ie its slightly conical, not cylindrical
    pushing the front of my screen down leads the sides to angle in ever so slightly, which sort of matches the turret
    if yours material is stiffer and the front is lifting too much, perhaps re-design the screen template so that the bottom edge is not straight, but the sidewall bases angle down by a few mm as they head towards the front tabs
    Michael
  • Senator
    Have managed to draft up a template for this, looks ok (just fits onto 1 A4 piece of paper) and if I have the measurements correct, should work out well.
    I have a laminating machine at the shop, so will run through a blank pouch to stiffen up the plastic, should be about the right weight / stiffness I reckon. Could always put in some funky sort of coffee bean design and sell em on trademe (NZs evilbay
    Sen
    My solution for my messy EM0450 was to replace it with a Gaggia MDF. :P
  • Alistair1
    [img][/img]
  • redzone121
    Love it, well done !
    CB
  • jakes
    Ive used a 2 litre plastic milk bottle, top and most of one side cut out with a slot for the grinder spout. I read about the idea on here - and Im sure theres pictures of the original floating around somewhere.
    Its certainly not quite as attractive as the clear perspex in this thread, but it didnt cost anything, didnt take very long to cut to size and its pretty effective.
  • Senator
    that man deserves a DB
    Great design MCR, will have to get the Mrs onto trying to make something up, mine would end up looking like a dogs breakfast
  • cksyd
    Nah - prefer the perspex myself
  • mcrice
    I wondered, actually, if one could be made out of one or more aluminium cans
    Youd probably need tall ones, I could recommend Guiness or Kilkenny. Or Mother, if its really the caffeine youre after.
    Perhaps joined with double-sided tape to get sufficient length? There would be a way of crimping too.
    You can cut cans nicely with a stanley-knife blade, held flat at an appropriate height eg on a book, but rotating the can and scoring deeper and deeper. Scissors or snips tend to give a stretched/buckled edge.
  • cksyd
    Thanks Michael
    Legend.
    Ill have a crack at it this evening. Looks at least to be a 2 or 3 beer job if taken seriously ;D
  • mcrice
    heres the pattern, though I drew it on graph paper, that hasnt come out in the B&W scan
    also, I have no idea what size it might print out for you
    it might be necessary to rotate +/- re-size the image
    the screen in this template is 300mm wide/long and 146mm high from the flat base to the peaks (not counting the tabs at the base)
    theres a 20mm scale on the template, if that helps
    if anyone has specific ideas for scanning and formatting this, please let me know by forum or PM
    Michael
  • cksyd
    Nice job mcr!!
    I have the Sunbeam spout but those side walls are really neat. 8-)
    Any chance you could post your pattern up here?
    ...also sick of the splatter...
