Clean your grinder!
  • #16
    Re: Clean your grinder!
    Originally posted by 6C594A484E522B0 link=1241643673/13#13 date=1241693733
    Try a kitten
    Too late...its now dried on.
    • #17
      Try a damp kitten then
      • #18
        RSPCA.... This is now OT.
        You could try some 3M SS cleaner / polish
        • #19
          Looks like coffee tumor growing in the throat of the grinder.... yuck
          • #20
            Originally posted by 4579647F757463767E75110 link=1241643673/11#11 date=1241677524
            I have some spots on the doser of the Macap.
            Probably splashed milk.
            Any suggestions for removing it?
            Try Autosol plastic polish. Specifically for plastics, even takes opaque plastic car headlights back to clear without scratching.
            You would only need the tiniest application to get rid of it.
            • #21
              Originally posted by 566A776C666770656D66020 link=1241643673/11#11 date=1241677524
              Wet the milk stain by
              1) Pressing a hot damp sponge or microfibre cloth to soften the milk
              2) Wipe off gently with the hot but squeezed microfibre cloth
              Easy as
              • #22
                Ill try a few of those suggestions and see how I go.
                I did buy a SS cleaner the other day, as suggested by someone at Cafebiz that had a Macap on display, but it hasnt worked.
                Ill point out that the spots are on the metal part of the doser.
                • #23
                  I heard that you can clean a grinder by running oats through it. Does anyone know if this is true??
                  • #24
                    I wouldnt!
                    Unless you want bits of oats all over the internals as well.
                    There is a product called Grindz that is designed to put through a grinder as a cleaning aid, but I still believe the best way to clean is to at least get the top burr off and get in there.
                    Some use vacuum cleaners or compressed air to assist. Personally, I use a dustbuster with some small attachments to help out.
                    Personally, the only thing I ever want to run through my coffee grinder, is coffee.
                    Brett.
                    • #25
                      Yeah...there could always be the possibility of weevils in the oats, which may make for some strange tasting, non-vegetarian coffee! I will continue to take apart and enjoy the time spent with my grinder...
                      • #26
                        Originally posted by 734F5249434255404843270 link=1241643673/11#11 date=1241677524
                        Ive no idea if this would work, but have you tried putting the affected bits under the steam wand of your coffee machine to steam the dried milk off? Might need to make your steam wet though.
                        • #27
                          Eeeuw. Never, never, never shall mine become... fossilised. Wheres that chisel? I need to work off some serious shock adrenalin. ;D
                          • #28
                            i have a Carimali grinder which i try to clean regularly... but generally persuasive as i may be, i can not get the lower burr carrier off the spindle.
                            i tried a lot of things, from lubricants to gentle heat, but the thing wont budge.
                            i cannot lever it off either: tried that too and the amount of force i applied would have been at the upper limit before running the risk of distorting the burr carrier, which is made of ( soft) brass.
                            so, i clean it above the burr carrier and then use a variety of short bamboo sticks, cotton buds, paint brushes etc to scrape as much of the crud from under the burr carrier, all the time working through the grinds chute.
                            troublesome, but reasonably effective... and at least i end up with the feeling that i did my best to clean it
                            nevertheless, if anyone can point me in a new direction as far as trying to get the stubborn thing off, feel free!
                            L
