Id suggest a good quality hand grinder. At approx 9g per shot
coarse grind, grinding time is minimal. Big advantage is that
an important criterion for cupping, amount in = amount out,
is easily achieved.
I have one sitting on the shelf set to the grind I like for Chemex
filter. 18g for two cups grinds in about the time it takes for the water
to heat.
