AROMATIC PRO Grinder by Nemox
  • AROMATIC PRO Grinder by Nemox
    hi i would just like to know if anyone here owns one of these. And if you could tell how you are finding it? please help, i need to buy a good grinder soon. :-/
    thanks agian.
    Re: AROMATIC PRO Grinder by Nemox
    Why are you looking at this particular grinder? Is it even available in Australasia? Plenty of tried and tested options out there that people will recommend. Going on the pictures most of them have a smaller footprint as well.
      Originally posted by 41595C5C495873414D421A1B2C0 link=1253922802/1#1 date=1253923304
      hi muppet, im in new zealand by the way. Im looking at this grinder becuase it is within my budget to acquire this second hand from a website. So i just want to know what they are like. I need a good grinder for my sunbeam em0610.
      Any help is appreciated.
        This looks like an upgraded Nemox Lux
        I think it will be suitable for your needs
        However test it first if possible
          Originally posted by 7F5B525251516B7F5B47595B340 link=1253922802/3#3 date=1253930886
          Based on what? It looks nothing like a Lux.
          It looks like an espresso machine without a group. I cant find anywhere that says what kind of Burrs it has, type of burr carrier, steps or stepless. One site says that it has dose control of some description.
            Originally posted by 76525B5B58586276524E50523D0 link=1253922802/3#3 date=1253930886
            hi KK,
            Yea the model im looking at looks like that. But i cant seem to find any detail review of it on the net. :-?
            Plus i would also like to know if the grind settings are steps or stepless.
            Thanks agian,
            Anu.
              Originally posted by 3B342F233B3E3B2C5A0 link=1253922802/5#5 date=1253937959
              hi KK,
              Yea the model imlooking at looks like that. But i cant seem to find any detail review of it on the net. Huh
              Thanks agian,
              Anu.
              Hope this helps
              The Aromatic Pro grinder is an automatic, professional coffee grinder and dispenser, designed to maintain the coffees quality and aroma intact.
              The body is stainless steel and the mills are conical in hardened, tempered steel to guarantee durability and excellent performance.
              The powerful motor is equipped with a reduction system that allows the speed to be reduced from 10,200 to 800 RPM.
              A low milling speed ensures that the coffee is not overheated, which might lead to a burnt flavour.
              5 Ground Coffee doses always available
              Automatic grinding for reservoir refill
              Discharge function for ground coffee
              Rating: 230V 50-60 Hz Power: 150W
              Coffee Container Capacity: 500 grams - 17.5 oz
              Weight: 10 Kg
              Dimensions: WxDxH 220x330x470mm
                Originally posted by 547079797A7A4054706C72701F0 link=1253922802/6#6 date=1253941188
                Garbage.
                800rpm wont achieve that. More like 300-400rpm required.
                Power: 150W
                Weak as water.
                Lots of hype and not much substance in the spiel.
                  Originally posted by 76575C5C5B41320 link=1253922802/7#7 date=1253946262
                  Weak as water.
                  Google is a friend
                  It was a cut & paste info
                  The decision remains with Anu
                  What price is it Anu ??
                  I ask this to see if a better grinder is available for the money
                    Originally posted by 052128282B2B1105213D23214E0 link=1253922802/8#8 date=1253950667
                    Google is a friend
                    Wasnt meaning to have a go a you KK - I realised it was a cut and paste and that you were simply being helpful.
                    I was just having a dig at all the hyperbole some marketing teams come up with.
                      Weight: 10 Kg
                      So its a Lux with ~8Kg of stainless steel bolted on  :-?
                      Doesnt look like cleaning the burrs will be as easy :
                      Also found http://www.nemox.com/uk/production/pro_grinder.html
                      "In the distribution chamber there is a constant amount of approximately 30g (1.05 oz) of ground coffee.
                      By grazing the distribution button with the filter carrier, 7g (0.25 oz) of coffee are dispensed instantaneously
                      Thus, the mechanism planned by Nemox allows to obtain doses of ground coffee almost instantly, thus protecting both the coffees aroma and preventing its getting stale."
                      So it must be some sort of electric doser ?
                      I dont understand - how doesnt the 30g of ground coffee get stale ?
                        Originally posted by 77676576617D040 link=1253922802/10#10 date=1253966851
                        Weight: 10 Kg
                        Perhaps it is 8kg of accoustical shielding given that my Lux is only slighlty quieter than a 747 landing. As for the coffee staying fresh, I cant imagine how that would work given that it is already ground when waiting in the chamber. Is the chamber some sort of vacuum?
                          Wasnt there a better version of the Lux demod on Home Barista a little while ago? Id be waiting for that one to arrive in Oz before tackling the one above, if youre set on this style of grinder...
                            Originally posted by 3A2A283B2C30490 link=1253922802/10#10 date=1253966851
                            Weight: 10 Kg
                            HI scarey, i was thinking the same thing.
                            The description of this grinder and even the picture looks so confusing. Even after reading the description i am not sure how it works.lol Therefore i will wait for a Ibertial Chanllenge grinder i think. They have prety good reviews and are just within my price range( if bought new).
                            Only thing is i dont know any shops in New Zealand that would sell these grinders? If anyone has bought one of these in nz please let me know.
                            thks,
                            Anu.
                              [QUOTE=0F2B222221211B0F2B37292B440 link=1253922802/8#8 date=1253950667]
                              Hi KK,
                              the price of the nemox starts at NZ $300 on the auction so i am not sure how high it will go. I do know they are around $749 (US?) new. Might wait for the ibertial challenge. what do you think? :-X
                              Anu
