How do you modify Breville BCG 450 grinder?
  • How do you modify Breville BCG 450 grinder?
    my grider is not grinding fine enough to suit my brevell espresso machine. I need to slow doen the extraction rate so the coffeo machine is not able to do that, so i need to make a finer grind. How do i modify my grider to get a finer grind? Please ;D
    Re: How do you modify Breville BCG 450 grinder?
    Try searching on google
    e.g. http://newsgroups.derkeiler.com/Archive/Alt/alt.coffee/2008-02/msg00541.html
      Or, you could try searching the CS grinder section, which revealed this:http://coffeesnobs.com.au/YaBB.pl?num=1204007644
        Welcome aboard John Gough, enjoy the ride 8-)
          Got my hands on one of these yesterday and then started reading posts regarding the mods needed. So out came the tool kit and I went to work. all went well except for the fact that the first time i used it i found that the original espresso setting on the unit is perfect for my machine!! I Tried the finer setting achieved by the mods but it would not let any water through during extraction.
          So mods were successful but not required :-[
          Phill
            Hence the old saying "If it aint broke...."
