Re: Cleaning Super Jolly
Ive gone the way of WSully and set up a rechargable handheld vac with an extension hose and it keeps my grinder and coffee area spotless. ;D
Originally posted by 594F4B484B59592A0 link=1269842306/13#13 date=1271483568I have found an air compressor (with obligatory safety glasses) to be a very efficient cleaning aid for my SJ.
NEVER use a compressor near a grinder....Its a perfect way to drive coffee into places where it should never go...
I did a major strip of the SJ when i first got it, i now have a vacuum mounted(hidden) in my coffee cabinet with just the hose poking up the back that i use after every time i dose, it does the tray, forks, doser and chute, not a ground in sight!
and no build up either....picked up the vac for $10 off gumtree
Thanks for the input folks.
Grinder is stripped, scrubbed, dryed and rubbed. Looks like new and ready to grind some beans for the morning ritual.
This site and the people that frequent it are so amazing with their help and advice.
Thanks again
Chester
I removed the flap and switch as a unit, it is a little involved as you have to jumper the connections inside the grinder, but gives you access to the chute in order to clean it out, tonnes get stuck in there......
Just took the bottom burr carrier out, not bad but still a little build up that I wouldnt want my coffee coming in contact with.
Sound like a bit of a snob there. ;D
I left it factory standard & connectedOriginally posted by 2824382622281428243E3B272E79794B0 link=1269842306/8#8 date=1269846647Hi KK
Did you disconect the switch though, so it was only operating manualy
Chester
Hi KK
Chester
I left my overfill flap/switch in placeOriginally posted by 4D415D43474D714D415B5E424B1C1C2E0 link=1269842306/6#6 date=1269845451Did you just remove the flap Warren or did you take out the whole black switch unit?
Sorry for al the questions
Chester
Chester
Yep lots of petrified grinds get caught in a cavity but mostly under the bottom blade/burrOriginally posted by 5A5E786161647B6C630D0 link=1269842306/4#4 date=1269844450it can hide a few sins under there, just so you know its clean, its an easy job, just be careful putting it back together and avoid cross threading!!! It goes without saying, make sure its unplugged from the wall when ever you play around with it Roll Eyes
Keep us posted on how its going for ya Wink
cheers
warren
While you are cleaning pull the doser apart and do the sweeper mod
No biggy, i have removed the auto fill flap.....makes a massive difference to removing old grinds, i have also done the tape mod on the doser vanes.......makes a MASSIVE difference, it is completely clear of grinds when im finished dosing.....Originally posted by 6965796763695569657F7A666F38380A0 link=1269842306/3#3 date=1269843753Its a auto WSully would have prefered a manual but it was just to good a buy for its condition.
I did and i advice you do the same, it can hide a few sins under there, just so you know its clean, its an easy job, just be careful putting it back together and avoid crossthreading!!! It goes without saying, make sure its unplugged from the wall when ever you play around with it :Originally posted by 6965796763695569657F7A666F38380A0 link=1269842306/3#3 date=1269843753Is there any point taking out the bottom burr carrier for cleaning, as there is no visual signs of any oil residue after just giving it a quick go with the vac.
cheers
warren
Thanks for the advice, I will start with super hot water and go from there.
Chester
as per leehams post, great advice IMO, congrats on the SJ! I love mine, I did the same, $500 near new from 9bar, is yours an auto or manual or timer?Originally posted by 6C606964646D010 link=1269842306/1#1 date=1269842587if its metal I would start with a HOT damp cloth with a bit of coffee machine cleaner stuff in solution and work up from there.
if its the hopper i would do it in the hot water in the sink with detergant.
you dont have much control in the dishwasher, i dont trust ours to be gentle.....
