Sunbeam EM0480 problem
  • Sunbeam EM0480 problem
    Hi All,
    Im kinda new in the coffee world so be kind with my silly question... :
    Just bought a EM0480 on the recommendations of this forum and i just plugged it in and started grinding away playing with my new toy, and noticed that not much coffee was coming out so i gave it a "little tap" on the side and all this fresh coffee come out??? When i stopped the grinder when i was done i gave it a tap again and about 1 - 2 tablespoons of coffee grind come out.
    Is this normal guys because that is a lot of waste i believe and how do you know you will always have fresh grinds if there is always what i believe to be a substantial amount sitting inside the housing.
    Thanks for your help everyone!
    Re: Sunbeam EM0480 problem
    Hi and welcome to cs!
    I always brush and tap out the leftover grinds. Maybe a teaspoon or two.  If youre beans are quite oily they may clog a little more which could be why you had so much.  Or if youre grinding very fine.
    All the best,
    sd
      Yeah, I measure out my beans first and then rock the 480 back and forth at the finish of the grind and get about a teaspoon or 2 out as well.
      Have pulled it apart after doing this and am happy with the tiny amount left over.
      I have been doing this for over a year now and the grinder is still going strong.
      I also grind into a metal jug and get virtually no mess or clumping.
