Doserless Grinder Modification - Macap MC4
  • sharkroman
    Digged out this thread to share my recent mods to the Macap MC4 including a not so well-done chute mod and metal wire to reduce clumping.
    Previously had 10g~ in the chute every time after use, need to remove with a chopstick, now retention is virtually 0, nothing comes out regardless how far I poke into the chute.
    Very good for single dosing with the precision wormdrive, now I have to decide to keep between this one or the Quamar Q50P..
ID:	747048Click image for larger version
  • HellEngineer
    anyone thought of mounting the whole grinder at 45 degrees to help clear retention from the burrs as per the EG-1 or kafatek monolith titan flat grinder?
  • doronby
    picture of 'mod'
    Does anyone have any ideas how to further improve the clumping and retention beyond above 'mod' ?
  • A_M
    Re: Doserless Grinder Modification - Macap MC4
    I just did 3 mods to my MaCap 5:
    A: Slight re adjustment to the Dosing fork... One side is now screwed in more and off sets the position of teh group.
    This off sets the dose being flicked to teh left and missing the hroup and basket. Note: A bigger issue for me when using a 54 mm basket.
    It also means no plastic or other crap being added to the system and can be easily put back if ever required.
    B: As per post 23 above but not so aggressive - A slight taper / grove put in (dremell and tapered round stone used) so that it assists in any physics needed to get grinds out. Also polished with wet and dry.
    C: Was not happy with the sweeper blades and the space between them and the wall. Added some mini angle pieces such that the over all OD has increased and a lot less free space to allow air pressure and grinds to by pass the blades..
    Wow what a difference.... Need a flap now to deflect the grinds down and into the doser... And dose is dropped smack dead into teh DMC group like a charm...
    Over all... Starting to like this grinder a lot... Still need a super mini hopper.... Enough for say 5 double shots or their about...
    With no hopper and the spare single DCM basket acting as a bean escape guard.. Enough space for about 1.5 double shots of beans to be dropped in....
  • kbc
    Thanks for posting the pic. I was slack :-[
    The pic is very similar to the mod I made - and described at the start of this thread.
    Regarding comparison with the K3. This was my upgrade from the K3. It is quieter, built better, has much better grind size adjustment control. I also believe the grind quality is better as my extraction time consistency has definitely improved. 100% happy with this one.
  • stucci
    Photo below of same mod, couple of hours with die grinder (carbide burr then emery flapper wheel), fine wet & dry paper then scotchbrite hand polishing.
    Grinder still has a significant avalanching problem, but I dont attempt to grind directly into the PF, so not a big issue. Some grinds are retained, but now quickly/easily dislodged with a chopstick.
    Overall a decent option for the "doserless" camp not wanting to fork out the extra $s for electronics, but would be interested in a side by side comparison with the K3T for grind quality & precision of adjustment.
  • A_M
    Originally posted by 0332263F2A676367530 link=1271046692/21#21 date=1272939896
    An update - The mod has worked well.  I now get only 1-2 grams stuck up the chute before using a brush to get it all out  ;D
    PICTURES..
    No pictures... Implied fake ;D
  • kbc
  • Ronin
    Originally posted by 4C6861616262584C68746A68070 link=1271046692/17#17 date=1272436210
    I meant cleaning off the brasso before coffee use
    It was a joke KK,
    but in thinking about it more, the brasso might leave a residue that would need a mild solvent to clean eg. metho.
    Also as brass holds heat well the coffee grounds could get hotter therefor getting stale quicker (another one for you KK )
  • Koffee_Kosmo
    Originally posted by 090D2B323237283F305E0 link=1271046692/18#18 date=1272436498
    Ok sorry :-X
    I still like you warren :-* :-*
    KK [smiley=beer.gif]
  • WSullivan
    Ok sorry :-X
  • Koffee_Kosmo
    Originally posted by 0400263F3F3A25323D530 link=1271046692/16#16 date=1272435584
    KK I think it says at the top that they are having difficulty cleaning the chute without the mod......
    In any case as I recall from my M4D its near impossible to clean the chute without removing the spout assembly
    I found it easy and quick to use a vacuum cleaner
  • WSullivan
    I cant believe this thread has no pics! Its not a mod thread without pics! ;D
    PS there are well designed roasters out there too, but you reinvented the wheel too! And for the record, I really love your wheel! Lol ;D
  • topshot
    Originally posted by 7D5950505353697D59455B59360 link=1271046692/14#14 date=1272430881
    Whats so hard about a thorough clean after using it
    Diito
  • Koffee_Kosmo
    Originally posted by 103C3F3A3D0C04530 link=1271046692/13#13 date=1272430187
    Possibly Brasso to finish it off. Not sure if its food grade tho
