mazzer spitting to the left, compak dropping clumps
  • A_M
    Re: mazzer spitting to the left, compak dropping clumps
    [QUOTE=625249474854455273494445200 link=1273581482/22#22 date=1273842529]
    Originally posted by 47686163744B67686761636B636872060 link=1273581482/1#1 date=1273582264
    Originally posted by 4D56575C5C390 link=1273581482/0#0 date=1273581482
    Outcome.. Doserless  8-)  I can manage... large quantities of grinds over the bench top = NOT
    Mark... remember my DIP DK 30? 80mm Blades and large spout = surface area covered with grinds  ;D ;D Hey at least it gave us coffee quickly!
    VERY LARGE surface area..... AND floor as well... Wife would just shrivel / start to implode and then I would be DEAD
  • SupremeRoasters
    [QUOTE=47686163744B67686761636B636872060 link=1273581482/1#1 date=1273582264]
  • bikpaintr
    I use a plastic milk jug version of the Schectermatic in my SJ.
    http://www.home-barista.com/grinders/how-to-tame-messy-mazzer-doser-t6499.html
    Works fine & doesnt require removing the doser bottom to install. The doser on my WBC is a huge improvement over the Mazzers Ive owned & doesnt need all the little mods to work properly.
  • Koffee_Kosmo
    Originally posted by 0E0A2C3535302F3837590 link=1273581482/19#19 date=1273641549
    Got any pics KK? I think i remember a post when you got the Major, but i think that was the placky mod, interested in the alloy one 8-)
    Yes photos and a video below
    I still have the plastic version and if anyone wants it its yours for free (note you will need to remove the bottom of doser to fit)
    [media]http://www.youtube.com/watch?v=N3Dy3jv2h1M[/media]
  • WSullivan
    Originally posted by 57737A7A79794357736F71731C0 link=1273581482/17#17 date=1273638076
    I went with an aluminium style on a remake for my Mazzer Major
  • A_M
    Originally posted by 7B716473737C686E1D0 link=1273581482/14#14 date=1273630507
    Brilliant! The looming prospect of marriage hasnt dulled your creative instincts. Neat as!
    Ya ... But its only looming and he is distracting him self..
    Give it 2 years
    Or is that 7 / 21 / Life
  • Koffee_Kosmo
    I tried the plastic but was not pleased with it
    The one I made was a half circle spout where sullies is a full circle spout
    The full circle design may have better merits
  • A_M
    Originally posted by 5556444440564E370 link=1273581482/11#11 date=1273624426
    As David Seng has pointed out before, if you pull the sweeper quicker on a Mazzer the grinds hit the outlet wall and drops in the middle of the basket.
    You can even get the grind to drop to the right, if you go fast enough.
    Fair enough... In a shop etc
    At home with Wife and kids ;D NOT
    Originally posted by 6064425B5B5E415659370 link=1273581482/13#13 date=1273630261
    Introducing - THE SULLINATOR 2010
    This weekend...
    Opps.... How do I explain a NEW shiny SS grinder on the bench... Bugger.
  • WSullivan
    Disconnected that silly Auto starter too, finally.....one of those "things to do" that we never do :
  • flynnaus
  • WSullivan
    Just did it then, took 1 hour, works perfect!
  • flynnaus
    The only mod Ive done to my MM is the sweeper arm tape. Its easy to change your dosing technique.
    My solution to the throw problem is to hold the group handle closer to the doser exit rather than resting it on the fork. I can also then easily rotate as necessary.
    If you grind through the doser (ie thwack the dosing lever while it is grinding and thwack at the right speed (fairly quickly for me - snap to what BassWay said),  throwing isnt a problem. When the grounds reach the rim of the filter basket, I tap the handle a couple of times to settle the grounds before filling and tamping.
  • bassway
  • WSullivan
    This one?
    Elvinator
  • swig
    Hi,
    I got the template of the guys site. I cant find it at the moment. There was a link in one of the comments on the pictures. It gives you a full size template.
    I can look for the file or link later.
    Martin.
