Mazzer Super Jolly Electronic
  • #31
    Re: Mazzer Super Jolly Electronic
    Gday Muscles,
    Im using the double shot basket supplied with the Giotto Rocket Evoluzione. Thanks for the hints - I am getting very close to the shot that I want.
    What is this three letter acronym "VST"? Im not familiar with it, so Im not truly understanding what you are communicating.
    Lawrance
    • #32
      Its a manufacturer of espresso baskets.
      http://coffeegeek.com/opinions/markprince/04-29-2011
      Greg Pullman sells them, although there may be others
      • #33
        Hi can anyone tell me why a SJ-E is so much better than a Mini-E?
        Id be REALLY pushing to fit a SJ-E in my space, so looking to the Mini-E; but it gets poor reviews - I cant work it out :S
        Slower grind speed I understand....
        But grind quality?
        Doser timer accuracy?
        If anyone can giv eme the height of the SJ-E with the shortest available hopper, id like to know
        Cheers!
        • #34
          Grind quality is probably similar, but the timer is digital on the SJ-E and analogue on the Mini-E
          Digital = you set the time using buttons and can be set in 0.05 sec increments
          Analogue = timer is set by turning a screw driver - you cant specify an exact time
          • #35
            Originally posted by 2A293C3A3038352938372D2A590 link=1284891870/33#33 date=1320730618
            Well put SPs, if you want digital precision in a MM size look @ the M4D......that is of course if the styling of chrome.
            Steve
            • #36
              Thanks for the reply...Im guessing theres no way to shoehorn the SJs Electronic doser timer on to a mini-E..thatd be too easy.
              It turns out the height of the SJ-E even with shortest hopper is still >60cm, so too tall for my cabinets. & Id like to have at least 100gm worth of hopper capacity.
              I guess its a Mini-E for me then. :-/
              • #37
                Did you know you can get a smaller hopper for the SJ E, like I did.
                • #38
                  The SJ-E is 510mm with a standard mini hopper. A super short hopper would lose a further 30-40mm.
                  Not sure about elsewhere in Australia, but they are almost impossible to find in Melbourne at present. We can get them, but there are not many.
                  • #39
                    Just got my SJ-E from Chris today.
                    Love it. We have a mini-e at work and SJ-E puts it to bed. Heaps quicker, at least double the speed & no mess. Its not much bigger than the mini really. Especially with the super short hopper.
                    Thanks Chris
                    • #40
                      Crikey I thought my hopper was short, that really is short!
                      • #41
                        Tis a nice hopper to have!
                        Java "Yes size does matter! ;D" phile
                        Toys! I must have new toys!!!
                        • #42
                          [split] [link=http://coffeesnobs.com.au/YaBB.pl?num=1320814204/1#1][splithere][/link][splithere_end]
                          • #43
                            Originally posted by 073B263D373621343C37530 link=1284891870/8#8 date=1286379583
                            Originally posted by 6D40444845290 link=1284891870/7#7 date=1286371030
                            I tried Babel Fish but I still cant work out what you mean Leeham..... :-?
                            Try "Can you buy just the chute from a doserless Super Jolly?"
                            Hi, is it possible to modify my existing SJ to a d/less electronic?
                            Where do those VERY short hoppers come from. Cheers.
                            • #44
                              You can buy a kit to add on the dosing cone, in place of your doser - BUT it is very expensive.
                              Im not sure if Mazzer have a retrofit solution for the timer, but you can use an external timer or if youre handy with electronics and 240V you can build in a timer on the grinder itself - its been done on someones Robur.
                              • #45
                                Any coffee machine specialist selling the Mazzer grinder will be able to get these short hoppers. I got a "medium" sized one that can take 1/2 kg of beans, but theres a "mini" sized one that takes less.
                                You should also be able to find these hoppers on eBay, but of course, its better to build a relationship with a coffee specialist rather than a faceless nameless eBay seller.
