Re: Breville BCG800 Smart Grinder
Just take the BSG back to where you bought it from and tell them it doesnt grind fine enough, even with the shims provided from Breville. Check the series number on the bottom of the grinder though, cause if you get another one of the same series and have the same problem then talk to Breville directly.
Hey mgrobins. I have the same issue with mine. I needed to install 3 shims to get it to grind fine enough, and it only grinds fine enough when its at least 1 notch finer than where the burrs start touching. Id be interested to know how many others have this issue too!
By this do you mean you already had a BCG800 that worked well - as in grinded fine enough without the burrs touching... and the one you got on Friday is your 2nd one where the burrs touch?
Originally posted by 54717E7E7F7B100 link=1288871951/854#854 date=1330930493
