Dosing from a Rocky Doser
  • Clonetrooper
    Re: Dosing from a Rocky Doser
    THanks Fatboy. Should have done it a year ago. It now doses a treat!!
  • fatboy_1999
    I think it is meant to separate your clicks into 7g doses. However, I didnt find it useful when making 2 or 4 coffees at a time, so I removed it. And since you cannot adjust the grams per click, I thought Id just try life without it. That was about 2 years ago now.
    So - yes, Rocky can happily exist without it.
    We are going to have a number of people at our place n the next few weeks, so I am toying with the idea of putting it back in to see if it helps at all when I grind a large volume (IE: 10+ coffees in quick succession).
  • Clonetrooper
    There are many who remove the separator from the doser....Is there a purpose behind this piece of stainless? or can Rocky happily exist without it? I wonder what is was originally designed to do?
  • fatboy_1999
    I just grind what I need for each shot.
    Ive removed the separator and done the tape sweep mod.
    Grind
    3 clicks into PF
    Tap on bench
    3 more clicks into PF (grinder is now empty)
    Tap, level, tamp, load.
  • tasadam
    I have this doser as well. I use a scientific method here - do a half-pull on the lever - not quite to the click, and get a bit more. If its too much, I scrape it in to a flat dish that I keep underneath the doser tray to catch crumbs.
    Cheers.
  • Clonetrooper
    Much appreciated, thanks.
    Originally posted by Clonetrooper link=1166351985/0#0 date=1166351985
    Hi CSs,
    Does anyone know whether the amount of coffee from one click of the rocky doser can be adjusted?
    CT.
    fraid not CT...no can do....Just use the doser to sweep into the group handle and grind per dose....
    2mcm
  • Clonetrooper
    started a topic Dosing from a Rocky Doser
    Hi CSs,
    CT.
