I took apart my Rocky tonight for the first time since I bought it (2006?). What I found was horrible, the built up rancid coffee stank. I got rid of 99% of it with cocktail sticks, my grouphead brush (actually pretty useless here) and a vacuum cleaner. However, while the gunk is gone, the rancid oil coating and smell remains. Can I use hot water and cafetto to clean the brass? If so should I take the burrs off? Can I clean the bottom burrs well (the "agitator" vanes are pretty grimy). Would "Grindz" get rid of the oils? I just want to get back to "square one" and then of course now Ive seen the horror I will be cleaning every month
(bad pun) way to clean things up if you havent got the time to strip the top of the grinder down.
