Does anyone else have problems with the mini mazzar spiling coffee out to the left,l have played around with the doser which didnt make any difference.
Search for Schectermatic. Its a tiny paper funnel you can print, cut and stick in the underside of the doser, makes for dead straight dispensing. I have it on my Mazzer. Will try get a pic for you
* edit: link to pic. http://thebeaningoflife.com/schectermatic
I should mention there are a number of solutions for this, but this is the easiest and cheapest in my opinion. If you have a printer and a sheet of paper, you can do it. Mine has been installed for over a year now, probably should replace it, it looks a bit manky now
There are some schmik commercial solutions, like a fancy plastic one you can install by dismantling your doser.
I sometimes wish I bought the mini-e, especially considering I usually only ever make one single brew at a time. I dont need the measured shot as I already dose the hopper with only what I need for one shot. Sometimes I remove the hopper, and just fill the throat of the Mazzer with the measured beans, and close it off with an old tamper. I would be keen for an off the shelf chute conversion of some kind. Replace the doser with a simple shoot.
I made mine out of a thin ice cream container from the same template. It seems to work really well. Thinking of using an overhead transparency next time.
