Cimbali Junior cleanup & a few questions
  • #16
    Re: Cimbali Junior cleanup & a few questions
    Had a proper read through now I think and cracked the first Coopers Stout 8-). My two Cimbalis are a touch different to yours but share most components. One of mine is a belt drive DRM (the actual manufacturer) so slower speed burrs while the other is more like your junior. However both of mine have the conical/flat burrsets.
    There is a fair bit of shaft above the upper bearing before the burrs so if in doubt replace them bearings are cheap and dont lose the wave washer!
    Originally posted by 6F7C7A636F600E0 link=1309103467/0#0 date=1309103467
    should there be a stopper somewhere on the machine?
    No stopper on them and the numbers mean nothing other than a relative number. One of mine runs at -1 and the other at 3ish for espresso.
    the grounds started to clump quite a bit, is there anything that can be done to avoid this
    The clumps if your getting them will only be soft clumps and oily beans could be part of the cause so dont panic they are not hard clumps like some of the smaller grinders can give. Excessive wear on the cutting section of the burrs could be an issue with this.
    Originally posted by 6F7C7A636F600E0 link=1309103467/4#4 date=1309701219
    "interference" fit in between the vertical "sweepers" of the bottom carrier,
    No mine do have a bit of movement between them.
    The Radial difference of .35mm is wrong so either the lower burr carrier or the burrs are not quite machined correctly. That said my thoughts are that while not perfect the angle of the upper to lower cutting faces is fairly slight and there is a bit of flat surface after the bevel sections finish so they will still grind consistantly if they have life left.
    If you are failing to get a grind suitable for espresso without the burrs touching ocasionally with the tiny bit of vertical movement then I would shout it a new set of burrs, I suspect they are actually dead. Regardless of them being good or bad a new set of burrs will be a good thing to have in the drawer if you are going to keep the grinder.
    If you are buying new burrs make very sure you are getting the correct ones as over time several different ODs and designs were used.
    Off out for the night but on balance, slight woof in the lower carrier and worn burrs would be my picks.
    • #17
      Thanks bean... [smiley=tekst-toppie.gif]
      • #18
        Thanks heaps for your input FB
        I think you are right, the bottom brass burr carrier is cast/machined a bit out of whack, or maybe its been dropped in the past?.
        I am pretty sure the bearings are ok, as there is no play in them at all that I can feel/see.
        I dont mind getting new burrs for it, the local coffex place has advised they have genuine burrs available, but my concern is if the bottom carrier should be dead flat and centric, I will need a new one, and looking at an overseas parts website, it was in the hundreds of dollars!! I might as well get a new grinder. If the small intolerance is "ok" then hopefully the new burrs will improve things and it will be a nice usable grinder.
        Maybe I can pack up the bottom of the burr in the low spot with a piece of feeler gauge to get it more level?
        Are you able to tell if the burrs currently on my machine are genuine? What should the new ones look like (pattern wise) so I can make sure they are the right ones?
        • #19
          I was looking at the grinder while it was apart and thought I could perhaps turn it into a doserless model.  So my idea was to replace the front panel/doser with a new flat panel, and create a simple chute for the grinds to be directed to the PF.  My thoughts are I can make the chute easily removable (might hold it in place by magnets), then it will be very easy to clean out any old grinds etc.
          This mod will also be easily and fully reversible.
          I used a sheet of aluminium, and an aluminium angle for the bottom mount, which I secured to the front panel with double sided tape, which is very secure.
          Here is the sheet with hole cut out for the grind adjustment:
          Here is a close up of the bottom angle to secure the bottom of the front panel to the chassis.  I ended up shortening the bottom angle a little making it less deep, as it was interfering with the motor casting etc:
          Here is the panel temporarily mounted up:
          I need to cut a hole for the switch, on lamp, hopper "closer", and grinder setting ring that shows the numbers.
          I have completed a little extension for the chute out of the motor casting to the front panel, and will make some chute to direct the grinds into the PF, from the front panel out.
          Still not decided on the finish of the front panel, I might polish it to a high gloss or paint it.
          I will get some new burrs this week too.
          • #20
            On the burr question above mine are different but it is a different hybrid burrset so no real way I can tell.
            I did consider doing that with one of mine but as I ended up using them again for commercial work I left the dosers on. You may find you get some soft clumping of the grounds with the doserless mod too.
            For a simple spout option I have seen a few mods done with stainless kitchen funnels around the net.
            Enjoy your playing
            • #21
              The clumping issue I have been referring to (not sure if I am using the correct terminology) happens when the grind is set finer, and the fine grinds accumulate in the chute between the burrs and the end of the chute, instead of just flying into the doser as happens on the coarser settings.
              I will finish the doserless conversion and see how it goes, then get some new burrs and see what difference it makes.
              I will search for pictures of funnel idea, didnt think of using a funnel. I was thinking of using a bit of pipe/tube on an angle. I will have to play with it as the grind come out quite fast, and I think the angle will have an effect on where the grinds end up.
              • #22
                [split] [link=http://coffeesnobs.com.au/YaBB.pl?num=1310435808/0#0][splithere][/link][splithere_end]
                • #23
                  I finished off the front panel tonight.
                  This is the piece to extend the chute to the front panel:
                  The front panel fitted and grinder assembled:
                  Temporary external chute made up to see how the grinds come out:
                  Seems to be a bit messy, the grinds come out with some speed and bounce out of the PF somewhat, and the throat of the chute is a bit too big.  I might make the chute narrow down into a smaller size and see how that goes.
                  As I set the grind finer the grinds all start to jam up inside the grinder inside the internal chute, before even falling out past the front panel.  This makes it less messy depositing into the PF, but a pain the way I use the grinder for a shot at a time, as a heap of grinds stay there getting stale.  Is this normal for these sorts of grinders?  I guess in a high volume application, this is not an issue.
                  My wife is not too keen on this beast, what is it with women and their lack of appreciation for things mechanical with some macho styling???  ;D
                  I am not sure now whether to try a new set of burrs and see if the clumping inside goes away, or just get the breville smart grinder instead, and get rid of this one?
                  Any ideas on the approximate value of such a grinder?
