New grinder any my routines gone awol...
  • New grinder any my routines gone awol...
    Ive moved up a notch (I hope...) from an old doserless rocky to a nearly new Mazzer Mini-e.
    In the process of doing so im having a hard time getting back into routine. Its very early days but I wanted to ask for some advice as to how to take things forward.
    Experiences so far:
    (1) Compared to the rocky the mazzer is producing much more airy grinds. in doing so it typically tamps down more when using the same pressure.
    I thought this was a good thing because before i had to have the grinds in my rocky at near clumping to get the right brew time.
    The downside though is with the grinds level to the top of the portafilter before tamping the resultant level seems much lower in the puck. This seems to be leading to a wet puck... a couple of times ive removed the porta only to find the puck stuck to the top of the e61 head :|
    (2) To get the right pour time im finding that im running the mazzer at near max fine-ness. Twice ive near stalled the grinder (cant be a good thing right...).
    Also when its at this extreme it seems to massively affect the amount of grinds produced... in other words the timer on the mazzer is massively too short.
    Too be honest I feel like ive gone back to when i first started using a grinder and portafilter... im bouncing the settings around wildly in order to get back into a reasonable range.
    With a different grinder producing much less clumpy grinds should i be tamping more? Ive always read that i should always keep it constant its possible that ive always skewed it to match a different grinder.
    Could it be the beans? would the mazzer make the process more sensitive to their age? The packet is date stamps and are presently 5 weeks old... not exactly fresh but not so ancient that theyve dried out surely?
    Seems to me I need to back up in terms of grind fineness, allowing the volume to restore, but somehow restrict the flow more to compensate (tamp harder?).
    Ur thoughts please?
    Re: New grinder any my routines gone awol...
    Any lessons you learn with old beans you will need to re-learn when you get fresh beans.
    I dose to a rounded mound and very lightly tamp, but if you dont want to do that you could try a settling tap of the group handle then refill and tamp.
      I would try fresh beans and grind coarser but dose higher. Keep your tamp pressure consistent.
        We use a mini-e at work for decaf, our process is to
        - fill the basket with the double button,
        - collapse the ground coffee with a couple of taps
        - top up with the single button
        - distribute the ground coffee with a finger
        - tamp
        - brew
        - enjoy
        You might find that you get even more consistent results by slightly overfilling the basket and then leveling off before tamping.
          It might also be a good idea to get some digital scales and see how much coffee you are putting in the basket. 18 gms for a double is probably a good starting point although it will vary depending on how big your basket is and how low your shower screen is.
          Find a way of getting that weight consistent.
            Cheers guys. Will try to get some decent beans over the weekend and a set of scales
              Albeit with the best intentions at heart from the masses, I fear you are being led up the garden path.
              You dont need an alternate supply of beans, and you dont need scales.
              All you need to do is work out a new modus operandi for your new grinder. The method of operation / technique is obviously different to whatever you were doing with your last grinder, and this is nothing more than any professional barista has to do when he goes from cafe to cafe where they use different brand / model equipment....work out a modus operandi to suit.
              If you find & watch footage (video) of barista comps (ewechoob)....find the ones where the operator is using one of these programmable digital grinders similar to yours (but always bigger in size). Try their modus operandi, find the grind setting that suits your beans and whalla, your problems will be solved.
              Weighing the dose is irrelevant. Its the voluminous relationship between particle size vs tamp that counts for your particular bean supply (density). If you overfill or underfill for any particular weight, the black art doesnt work for you, and the black art is dependent on the tamped ground volume in the filter.
              Technique!
              Hope that helps.
              Attilio
              very first CS site sponsor.
                Five weeks old could well be stale, depending on the blend. I know that if I use beans that old that I have roasted with the blend i use, I would battel to extract a decent coffee!
                Weighing the beans is critical IMO to getting a good routine around your coffee making. A good barista (rare beast indeed!) can do it by feel and eye after training but us humble home-baristas need the aid of a balance to get anywhere near the required tolerances. The sweet spot for each machine, coffee and grinder obviously varies, but if you start of with say 16g then at least you have one constant to work with.
                Distribution is also critical, whatever method you use, it needs to get the ground coffee evenly spread in the porta filter, something like a tooth pick can help if the grind is clumpy or uneven.
                Tamping is less critical that many would assume, but again consistensy is the key, make sure you are tamping level and practise a few times on scales so you develop a feel for a particular pressure - how much or little is much less important than a bit of consitensy.
                Start of aiming to extract 32g of coffee in about 25-30secs and once you have the grind to achieve that, taste and then adjust to suit your taste. At least you will then have a reference point to work around and for the time being the main variable can be the grind size.
                  Volume changes with grind.
                  The finer the grind, the less volume a particular weight takes up in the coffee filter.
                  So if you weigh out 16 grams, grind "fine" (definition of fine?  ) and settle and tamp that into the (double) filter, you could be under dosing reulting in a less than satisfactory brew.  Some here would then blame that on 5 week old coffee instead of their technique.
                  This is not hard......The rule of thumb for me as far as dosing is concerned, is that if you can see the circlip groove of the filter, you have underdosed. Once settled and tamped, my puk needs to be at the top or slightly above the top of the circlip groove (again....I dont want to see the groove, but I dont want to be much higher than).....
                  Insert group handle into group and brew. Depending on how the brew runs out of the spouts, make a grinder adjustment.
                  Always fill to the same level, just at the top of the circlip groove (for my machines).
                  That is how I work out the correct grind, by always dosing to the same level irrespective of grind, and changing technque accordiongly to accommodate for grind (particle size).
                  If for academic purposes someone wants to weigh the unused puk (after they have worked it all out for correct grind) by all means weigh it then (at the end of it all rather5 than at the start) and see what you get.
                  Then put the scales way and never use them again because when you dose volumetrically to the same level (for any particular equipment) all the time, the weight will change according to the age of the beans and type of blend or unblended origin being used (density).
                  This system has never failed me and I chop and change coffees several times each morning during my cuppings. The grind changes and the technique changes to give the same volume in the filter.
                  "Distribution" is over rated. Not that the grinds shouldnt be distributed and tamped evenly, just that anyones method of filling, settling and tamping will obviously be to always try and do it all as well and evenly as possible.  Everyone should be trying to do that all the time ergo, no need to go over the top trying to do any better than you already are......except of course if an individuals distribution is absolutely lousy.  So perhaps I should say, to devote too much time in the day to discussion of the importance of "distribution", is to overstate its importance and that has the effect of making newcomers paranoid and insecure about doing all the "right things" or their coffee wont be any good. Relax.......enjoy.......no sweat.....
                  For academic purposes I should mention, 16 grams in one of the "regular" commercial double filters that most of us use in our semi commercial and commercial machines, constitutes a sizeable underdose. In order to slow the flow down to "spec", some users will then fine up the grind, when a much better espresso can be had by using the right volume of grinds in the filter (usually 18 to 19 grams if weighed), obviously with a coarser grind than the former to get a similar rate of flow, and the coffee is usually "sweeter" with much much more body.
                  A good example of a "16 gram" filter is the Italian market double filter that comes standard with the Silvia machine. Our style of espresso is better suited to the deeper commercial filters used here.
                  Lastly, this doesnt need to be that complicated....and the KISS principle rules.  I will repeat, my rule of thumb is fill the filter to the right level. Thats volume not weight. If you could do this by weight, Bialetti could stop producing its range of different sized stove top espresso machines and make only one size. You would then simply weigh out multiples of say 8 grams of grinds per person, and stick them in the biggest of the range of Bialettis. And you would drink dish water because that doesnt work.
                  Hope that helps.
                    Originally posted by 57637462794E527E77777474110 link=1337251224/8#8 date=1337326388
                    Wise words Attilio. You have a consistent technique whihc works for you.
                    Some would tell you that unless you weigh to +/- <1g of their nominated patented bullseye, you will never get a great result.. :
                    I am glad I can get by on my own reasonably consistent technique and use my palate to tell me whats right. ;D
                      Originally posted by 1F2B3C2A31061A363F3F3C3C590 link=1337251224/8#8 date=1337326388
                      Hope that helps.
                      There is so much in your post that flies in the face of conventional wisdom and the science of coffee extraction as i understand it that I am not sure where to start!
                      Perhaps its best to leave it to the OP to decide which path they want to pursue!
                        Am intrigued buy some of the replies, it tends to make me wonder if i was overdosing previously. I had no context of using the rings, only consideration was if it would fit into the head without binding.
                        Id fill the puck to top level and then tamp hard. It wouldnt go down much at all (suspect the grinds were excessively clumped to be honest). It would lead to a well timed pour but without any consideration for the amount of beans... but i sure did get through the beans
                        Doubt if it makes much difference but I pretty much only do a double - I love my coffee and a single seems like im being stingy
                        Ill try a few techniques posted here, i dont have a problem wasting beans provided it doesnt run into a kilo or more. Having spent $100s on the machine whats a bag in comparison if it means i get to use the machinery correctly.
                        And in the lightest possible way, please chill people
                          Hope that helps.
                          Probably just as well you didnt then
                          You are wrong on the conventional wisdom part and in regards to science, we are making coffee here, if you lose the art of coffee then get a robot to make it for you, I never weigh my beans or grinds or espresso and I am very happy with the coffee I make, and I enjoy making it
                          It sounds to me like you are using scales (science) to make up for a lack of connection with the coffee making process.
                            I dont want to hijack the thread, but if you dont understand why consistency and understanding of the process is a critical element to making great coffee - then you will only ever achieve it randomly, by accident.
                            If you are happy with the coffee you make, then I am happy for you. My goals are a bit higher!
                            Seriously though, this sort of discussion is now way off topic so I shall refrain from the temptation to further discussion.
                              What Attilio is basically describing is the Scottie Callaghan how to videos on the ECA website. He basically fills the basket to a standard routine each time, wipes off excess and tamps. This way you end up with the same volume each time and only need to adjust the grind as required. As I said above it sounds like youre grinding too fine and underdosing, but Attilio answered it more eloquently and accurately. Once you have a known volume of coffee which works for a particular bean you can then weigh it and use that weight for future shot reproducibility. But this will obviously change when you get different beans.
                              I actually think Galumay and Attilio achieve a similar result in the end. One by numbers and one by feel. Its the old art v science debate.
