I have just purchased a new Mazzer Mini grinder, it works just fine but when I place the portafilter on the forks while grinding it vibrates quite bad... metal on metal I guess but is this normal or not?.. thanks. :-/
Mazzer Mini vibration
Re: Mazzer Mini vibration
Not normal Oakie, I own a Mazzer Mini, no vibration at all under the conditions you describe, suggest you talk to the retailer you bought it from.Originally posted by 4C62686A66030 link=1338362406/0#0 date=1338362406I have just purchased a new Mazzer Mini grinder, it works just fine but when I place the portafilter on the forks while grinding it vibrates quite bad... metal on metal I guess but is this normal or not?.. thanks. :-/
Hang on everyone. Define vibration. Is there any vibration with the grinder on, whilst the portafilter is resting on the forks?? Of course there is - this is quite normal. Depends on how you define vibration. Its not meant to be very violent, but it does vibrate.
I agree Bennett, there is some barely perceptible vibration, which is quite normal, however Okie says his MM "vibrates quite bad" this is not normal.Originally posted by 23242F2F243535410 link=1338362406/3#3 date=1338375559Hang on everyone. Define vibration. Is there any vibration with the grinder on, whilst the portafilter is resting on the forks?? Of course there is - this is quite normal. Depends on how you define vibration. Its not meant to be very violent, but it does vibrate.
Thanks for your replies... I contacted the NZ Mazzer importers today and asked them to listen to the vibration through the phone.. it only took a couple of seconds for them to agree there is something not right and since I have only owned it new for one week they will send me a replacement.. fair enough.. cheers..D.
Good to hear Okie, hope all goes well with the replacement.Originally posted by 2F010B0905600 link=1338362406/7#7 date=1338447852Thanks for your replies... I contacted the NZ Mazzer importers today and asked them to listen to the vibration through the phone.. it only took a couple of seconds for them to agree there is something not right and since I have only owned it new for one week they will send me a replacement.. fair enough.. cheers..D.
Hey Oakie,
Did you find out what the vibration was? And did you notice any difference in the cup when you get the new one?
I bought a Super Jolly 2nd hand, and it's got a bit of a vibration when I rest the of on the forks. I'll take a video and post it at some stage, but it's definitely louder than other mazzers I've seen/used.
Bames,... no I never found out what the vibration was in fact it ended up quite nasty in the end... I demanded my money back and purchased a new Macap M4..
The vibration was that bad the portafilter was almost bouncing when resting on the forks.. made quite a noise as well.. The Mazzer was brand new.
cheers D.
