Replacement burrs for old enamel Gaggia MDF grinder
  • Replacement burrs for old enamel Gaggia MDF grinder
    I have recently purchased an old Macinacaffe Gaggia Grinder (Early 1980's). These are closely related to modern Gaggia MDF grinders, but have metal case vs the newer plastic model and a larger motor 155W vs the newer 100W model.
    It works ok, but the burrs are near their end of life. Does anyone know who may stock these burrs?
    From my measurements they have the following key dimensions: 50mm outer, 30mm inner and the standard 3 screw hole restraint.
    I thought the Rancilio Rocky burrs might fit, but the Gaggia burrs are "right rotation" were the Rocky's are "left rotation".
    Any thoughts?
    Kind regards,
    George
    I can't remember the name of the importer and think they may have changed anyway since I last bought an MDF part.
    Beat idea would be to email all the sponsors.
    There's a link on the forum somewhere.
    One of them may be able to help.
      The link to contact all the sponsors at once is the "Quote Form" which is accessible via a tab at the top of every page.
      Java "Click away!" phile
      Toys! I must have new toys!!!
        That's what that button is for
        Thanks you. I never noticed that button before.
          CoffeeParts should have them, I'm pretty sure the ones you need are: (Nuova Ricambi Part Number) 620347 - Right hand rotation, 50mm outer, 30mm inner, 7.5mm thick, 3 screw mounting.
            Thanks Morgan. Yep I think that is the replacement part I need.
            Moderators please note that the Quote Form is not working:
            'Form failed to submit. The following error(s) occured:
            The following users were not found:
            Portaspres'
              Quote Form fixed.
