EM0480... on notch finer makes a huge shot time difference! Is this normal?
  • EM0480... on notch finer makes a huge shot time difference! Is this normal?
    Hi Guys!
    So, I am really going crazy here... Setup:
    EM6910 + EM0480. EM0480 has 4 washers (with 3 I could only get decent grind at setting 3... now its 13 ).
    Issue 1:
    At setting 13 with 20g of coffee I get a decent shot but in 22 sec. So, I decided to make it a little slower... turn the notch to 12. Result: takes 40 seconds to get a shot and pressure is in the middle between brown / red area.
    I even tried 18 grams and 16 grams... same issue.
    How comes that one notch makes such a huge difference in extraction time? Assume tamping is the same in all situations.
    Is there an issue with my EM0480?
    Issue 2:
    Once I grind at notch 12... turning a notch coarser (i.e. 13) still yields the same results as 12... I end up cleaning everything to have the new setting in effect.. grrr
    Ideas? Suggestions?
