Simple stepped to stepless conversion
  • Simple stepped to stepless conversion
    Completely chuffed in my recent travels across the coffee cyberspace to stumble across such a simple solution for converting a stepped to a stepless grinder.
    Unscrew the burr retaining ring, take off the stepping retention mechanism, apply a small amount of plumbing tape to the ring, and screw it back in. A bit of fiddling around to get just the right application of plumbing tape, and voila, a stepless grinder!
    This simple, inexpensive mod has worked a treat on my trusty old La San Marco SM2, thereby overcoming my only gripe.
    I was so enthused that I lashed out and bought a new set of burrs. Now my shot making has improved 100%.
    Woo hoo.
    I am surprised nobody has commented on this - is it old news?
      I really need to do this on my office Gaggia MDF. I believe it's the most common way to go to a stepless rig if the grinder has a threaded burr carrier assembly.
      nice job mate
        Did a similar thing on my ANFM grinder many months ago so I can now make tiny adjustments that could not be done previously with the steps.
          Did the same also a while back. Easy and effective. Just replace the tape every time you give the grinder a good clean.
            In a word...yes !
            ..but you should have known that as you read about it on the net !
            It has been a standard mod on the Rocky for many years.
