Breville BCG450 v Sunbeam EM480/490 v Other?
  • CafeLotta
    I found that my own home roasted beans require a slightly coarser setting when they're fresher (about 5-7 days old). As they age over the next week (or 2 if they make it that far), the grind is adjusted slightly finer. If I use the same setting at 1 week as I do at 2 the brew will be bitter.
  • Journeyman
    I know swill... :lol: Had it quite a few times. In the past I have found asking for a double shot with an extra shot, no water and hot milk on the side gives me the best chance. Then I go out and do 50 things in 5 minutes while the buzz wears off...
    And to keep OT, I seem to have found my settings on the 480, but I have a puzzle. From my reading I was expecting my nice yummy beans from the local grinder would require a finer grind than the Vittoria ones I got from Coles. (I got them because I have friends that drink Nescafé 43 and I have grave doubts about the condition of their taste buds ) But the ideal grind for the V seems to be about 10 on the 480 and I'm out about 13 for the finer beans. If I come under that with the good ones they start undoing my handle even with a pretty light tamp.
    Maybe it is my variation in tamping. I might go find the old scales from the back room and do some practicing and train my muscles to deliver the same tamp consistently - also it might help me to get the feel of the difference between a 10lb and a 15lb tamp pressure.
  • Hildy
    you can see, though, how to do it properly would take too much effort in a cafe and you're likely to just get swill if you ask for it from the wrong sort of place.
    anyhow, if i'm going to drink something that dilute i'm going to aeropress it.
  • Journeyman
    What is lungo?
    EDIT: Ah, found it - from the 'Is there a FAQ' thread in General Coffee...
    Originally posted by Yelta
    I grind 2 or 3 steps coarser than I do for a shot, depending on the age of my beans, load and tamp as normal, start the flow and allow it to run for 30 seconds, when finished it is flowing lighter but nothing like clear/over extracted, what I end up with is approx 90 to 100ml of coffee with excellent viscosity/mouth feel, lots of flavour with no hint of bitterness or acidity and great crema, technically not a long black, most certainly not a shot but most definitely better than any cremaless full cup of long black (more often than not swill) I've ever had in a cafe.
    That sounds what I'd like, with just the macchiato hint of milk in it. Something to practice.
  • Hildy
    Originally posted by Journeyman View Post
    *grins* I take it you're not a mach drinker?
    I'm a mach drinker, I'm just not a lungo drinker. I think it's filthy bitter stuff.
  • Ancible
    Thanks All for your responses. Clearly there are many different views and I appreciate you all taking the time to respond.
    Originally posted by Hildy View Post
    to the OP: why did you buy a $1700 machine and budget $200 for the grinder?
    The original intent was to buy ground coffee until we could justify a grinder. The intent then changed to maybe buying a reasonable consumer grinder. The appearance of the Breville meant I need to decide on what to do now ... a bit earlier than planned.
    I'll update the thread when I've made my decision!
    Richard
  • Journeyman
    The course I did was a while back. I asked about basket to make sure I was thinking of the right thing. Thanks for the explanation. *grins* I take it you're not a mach drinker?
    Seeing I am apparently providing the entertainment have some on me...
  • Hildy
    basket = PF? Or is it to do with roasting?
    Are you sure you don't want to do some barista training? knowing what the bits of your machine are called is useful when talking to other people, or, for example, when asking for help disassembling grinders.
    That might explain why I have such a problem getting a good coffee. I always figured a Long Strong Mach was just an extra shot in a macchiato. T'Hooft here in Bendigo is one of the few places where they suggested I change beans to get my coffee. It also offers a reason why some of the old Italian places would give me my LS M in a picco cup...
    strong means different things to different people, and long means different things to different people. if what you wanted was an extra shot in a macchiato, that's what you should have asked for.
    if i was to make a long strong mach, I would change the 15gm basket to an 18gm or 20gm and grind coarser, with an aim to get maybe 100ml through it before blonding. i would then throw it away and make a ristretto to drink.
  • Vinitasse
    Originally posted by Yelta View Post
    Will someone pass the popcorn.
    I don't know whether to laugh or cry... but please pass the popcorn.
  • Yelta
  • Journeyman
  • Hildy
    @Hildy - you may be right - it would fit that the Faraday st place doesn't let their baristas change grind. To be honest I hadn't made that connection - to me they were professionals who would adjust their equipment to match the day, beans and demands of the crowd. It was an assumption. My bad.
    I didn't say that.
    I was gobsmacked at how easily I produced nice coffee with my purchase - having spent time on here and considering what I paid, I was expecting at best I would improve on Moccona instant but still be heading down the street for my long strong machs...
    you've just revealed your lack of taste. (-:
    (asking for a long strong mach is asking for trouble - you're going to get rubbish 99% of the time. to make it properly you will have to change basket and change grind - and what cafe has the time or propensity to do that?)
  • Journeyman
    @BO'S - I do realise the problems with being unable to alter the grind. In the end the inability to change things to improve the coffee I was producing was why I turned down the offer of work. But I have a red wine drinker's palate - I do tend to trust my taste buds and nose,. I have been comparing the Sunbeam output to the search across decades to find good coffee. I have 3 places in mind that provided a smooth, richly flavoured macchiato on a regular basis.
    So I asked, in my apparently inimitable fashion that gets people's hackles up, about the situation.
  • Journeyman
    Hey Chris, we are planning to be in Melb early April. I am happy to bring in my machine and learn. I don't have a big budget for upgrades but if I have a reason I can work on it... Do I just check your location in the Sponsors thread?
    EDIT: You are in Northcote? When we have a firm date for our travel (looking at somewhere between April 2nd to 6th - will know more next couple of days) I will PM with a request for some time. Thanks for the offer.
  • Hildy
    It is hard to equate the two - in both cases of pro machines I was not allowed to change the grind - it was 'checked' once a month when the providers came and serviced the machine.
    You say this...
    It has not really explained why people with what are apparently reasonable skills, fail to get consistently good to great results after spending thousands on hardware.
    and you really have to ask this?
    as for said place on faraday st... they're very hipster and hipster coffee may not be to your taste.
    it is possible, with good equipment and technique, to produce consistent, technically flawless coffee. it is impossible to produce coffee that everybody agrees is perfect.
    what sort of coffee do you drink?
