Hi. Got a near new Rocky today and it only seems to be able to be set at around 0.8 and 4
I pulled the hopper off the top and its a very simple mechanism. A series of little holes around
the bottom of the hopper and the little press button has a pin that comes up and sits in the holes.
Everything appears to be fine. The button is travelling all the way up and down and the little pin
is fine, not bent or anything but it still not locking in on anything other than the two settings above?
I noticed the two places where it is stopping the little hole in that area has been broken open a little.
I did the same thing on the area I wanted it to stop and it worked a treat, now stops in two extra
places where I opened the hole up a bit
Has anyone else experienced this problem? Any ideas? I pulled the hopper on and off 4 times and every
thing seems to be as it should be?
