Setting up a K3 Push
  • Setting up a K3 Push
    Hello,
    I picked up my K3 yesterday and have just gotten around to getting it out of the box, i have read the tiny instruction manual a few times but can't figure out how to allow full movement of the grind adjustment?
    It's like there is a screw i need to loosen to allow it to move?
    I've been looking at the Compak website and watching youtube videos but still not help! I will give the retailer a call tomorrow (they're not open today) but does anyone else know's what i need to do?
    There is a pin (metric screw) located under the collar which limits range. Remove the collar and it will all make sense.
      Thanks for the reply, i have loosened the screw underneath and now all good. is it ok to still sit in there loose?
        Originally posted by eggs View Post
        Thanks for the reply, i have removed the top part of the collar (un did the 3 allen key screws), but can't see any screw? There was another allen key screw which i removed but this made no difference. Do i need to remove the burrs?
        You shouldn't need to remove the collar.
        There should be a silver cap on top of the collar. Under that cap there is a screw which just needs a few turns out / loosen. Just a regular screw.
          Thanks Steve, i just loosened this as well. All seems to be going good. Pulled some good shots (massive step-up form my Sunbea, ) just fine tuning now.
            Does this even need to be removed? I haven't touched mine an getting a nice grind once I found the right setting
              You can download the K3 manual from the Compak site using the link below. The English section starts at Page 14.
              http://www.compak.es/docs/manual_Gourmet_8ID.pdf
