I have stuffed my EM480 in the cleaning process and wonder if anyone has suggestions.
I took the top of the grinding chamber (the silver grind adjustment "ring") off to clean the burrs. I got some water inside the plastic insides of that part so took it apart to dry. Clearly I have put one of the plastic pieces back in the wrong orientation. I put the top back on, using the arrows to line it up as usual. It clicked and turned as it normally does but did not quite go back. The machine now won't work either.
Now I can't get it back off and looking at it from the top, parts of the plastic are sitting down, instead of being flush. (bit hard to describe I know). I can twist it around and the button on the side will pop in the normal way that allows you to take it off. It just won't lift off and I can't take the top burr out either.
Is there a way to get the top off (the silver adjustment ring and the plastic below) from the motor chamber.... are does anyone have a suggestion? It looks like some screws will hold it in, but if I take some screws out they are so far down, the chances of getting them back in are slim.
I have tried some force, without luck - and was hoping to save it. Any suggestions?
