I've had a EM0480 for about 2 years now. When I first got it I soon worked out that at the setting of 13 I got just the right grind for my 800es machine. It stayed this way for about 18 months until eventually I needed to use a setting of 12 to get the same result, I figured that maybe the burrs were getting a bit blunt or something, no big deal.
After another couple of months I needed to go down to 11 at which point I thought maybe it's blocked up so it was pulled apart and cleaned thoroughly. So far so good, it was back to a setting of 13 to get the right grind. But after less than 2 weeks of using 13 I noticed the machine was starting to regress to a coarser grind. I'm rather perplexed that it would deteriorate so quickly after the clean had made it work like new. Any ideas on what could be happening inside the machine, could something be loosening, or what else could be wrong? Any suggestions most appreciated.
